Spray Paint or Auto Paint? - JeepForum.com
post #1 of 20 Old 10-17-2006, 04:30 AM Thread Starter
NCHornet
I am starting to clean up my frame and tub and will be coating everything in the KBS coating, similar to POR15. I will then use a black paint as a topcoat. My question is should I just buy a good quality spray paint for this for should I goy buy a cup gun and special paint from the auto body supply place. Is one any better than the other. Buying the cup gun is not a problem as I plan on repainting the Jeep myself. I would appreciate any advice on this.
Thanks
Kevin/TJ
TJ's CJ5
1977 CJ5 4X4, Soft top
304 V8 project jeep for my
16 year old son and I
NCHornet is offline
post #2 of 20 Old 10-17-2006, 07:31 AM
Bard
I have used both on frames, springs, axles, under the body. etc. I still do use a spray can for touch ups even after I spayed the frame with a gun. I just recently painted the frame and decided to go with a cheaper no name industrial semi gloss black paint and used a spray cup. It is faster and cost me less in the long run. You can buy a cheap spray gun for $30 bucks, paint is about $20 a gallon and it works pretty good.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #3 of 20 Old 10-17-2006, 10:21 AM
Indy
Indy's Avatar
Rustoleum by the gallon is about $25. It needs thinned a bit to run through a paint gun but works great.
Indy is offline
post #4 of 20 Old 10-17-2006, 10:24 AM
famicom21
famicom21's Avatar
i use an HVLP (high volume, low pressure) gun to spray rustoleum. works great when thinned a bit! plus, if you miss a spot you can buy a color matched rattle can and do some touch up
Yellow 86 CJ-7 Red 70 CJ-5
"Out on the road, out 'neath the stars, Feelin' the breeze, passin the cars."
famicom21 is offline
post #5 of 20 Old 10-17-2006, 12:13 PM Thread Starter
NCHornet
Not sure if I have seen rustoleum by the gal, but agree that would be the way to go. I normally buy the rustoleum in the can and have been happy with that.
Also how much do y'all cut it? I assume you are using lacquer thinner for cutting. I appreciate the info.
Kevin/TJ
TJ's CJ5
NCHornet is offline
post #6 of 20 Old 11-11-2010, 10:44 AM
bingx25
1983 CJ7
I painted my CJ with Rustoleum Regal Red. I found a site that recomended to use naptha to reduce it with. I mixed it 3:1 and it worked fine.
bingx25 is offline
post #7 of 20 Old 11-11-2010, 11:04 AM
bamasteeler
I just bought a case of Gillespie semi gloss od green in spray cans and am very happy with how the whole jeep turned out.
1980 Jeep CJ7
AMC 258, T176, D300,
AMC 20 REAR, D30 FRONT
1999 XJ CLASSIC
RC 3" front AAL rear
bamasteeler is offline
post #8 of 20 Old 11-11-2010, 11:43 AM
bamasteeler
this is mine done from rattle cans
1980 Jeep CJ7
1999 XJ CLASSIC
post #9 of 20 Old 11-11-2010, 01:37 PM
twildt
1978 CJ5
You painted your whole jeep with rattle cans? what brand?
twildt is offline
post #10 of 20 Old 11-11-2010, 01:58 PM
Jeepican
1976 CJ5
Ya i plan on using Gillespie Coatings also (lusterless desert sand).... look up rkbell... he did this to his and looks great!
Depends on your use of you rig.... are you wanting show quality or beat the crap out of it?
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #11 of 20 Old 11-11-2010, 02:12 PM
knowlwk@snowhill.com
1980 CJ7
Ahh... the great debate... I've done both, rattle-can and auto paint to my '80 CJ-7.
Rattle-can... takes about 13 standard cans of Rustoleum to do the exterior, plus 8 or 9 of primer if you want. If you take your time and prep things well, it turns out pretty good... not deep luster like a good autopaint, but shiny color. ( and the whole jeep is the same color... LOL)
Rattle-can paint goes on thin, and has no UV protection, so it will start to change color in a year or two... so when you spray over damage, the same color in the can will not match the paint on the jeep. It will lose its shine over 2 or 3 years and be pretty dull in 4 or 5. For a woods jeep... that's not bad.
The downside is if you decide 4 or 5 years down the road to paint with real paint, you gotta strip off all the rattle-can paint...
Tractor paint is the next step up, is cheap and is said to wear like iron. It doesn't have the UV protection of auto paint, and won't last as long, but is cheap and I read it turns out very nice..... but you gotta have a gun and compressor.
Auto paint can be cheap or expensive, and you'll need a gun and compressor. I shot my CJ with about $500 in materials with a $14 gun and $150 compressor out in my yard.... not a pro job (some bugs and dirts and runs here and there) but I am VERY happy with the results.
'80 CJ7, 258 W/Autojuicer, MC 2100, TFI, SummitRacing CDI, MORE SRS, Moser 1-pc, YJ tub on 1" body lift, YJ family cage.
knowlwk@snowhill.com is offline
post #12 of 20 Old 11-11-2010, 05:02 PM
bamasteeler
Yes I used Gillespie WWII o d green semi gloss took bout 9 cans so I ordered a case and am very happy with how it turned out.
1980 Jeep CJ7
1999 XJ CLASSIC
post #13 of 20 Old 11-11-2010, 05:15 PM
Jeepican
1976 CJ5
Did you prime and wetsand? What grit?
-Barney Fife-
Jeepican is offline
post #14 of 20 Old 11-11-2010, 06:14 PM
FamillyCJ7
1983 CJ7
Thanks
Kevin/TJ
I was going to go with KBS coatings as well until I found Chassis Saver and Monstaliner. Monstaliner is 100% UV resistant! If you haven't bought the KBS stuff yet look into the Chassis Saver and Monstaliner. Links are in my sig.
'83 CJ7 258I6 4-Speed Father Daughter Project - Using Monstaliner/Chassis Saver and Products from CrabTreeTool
NorthEastFL4x4.com - Local 4x4 Enthusiasts website, join up now!
FamillyCJ7 is offline
post #15 of 20 Old 11-11-2010, 09:29 PM
bamasteeler
I sanded any bad spots with 180/220 then primed any bare metal or areas I sanded alot the scuffed entire jeep with scotch Brite pads maroon ones then wiped entire jeep down with grease/wax remover
1980 Jeep CJ7
1999 XJ CLASSIC
Painting???WOuld it be tottally stupid to paint with spray cans Smitm16 Jeep CJ Forum 29 09-24-2009 07:59 PM
Spray Paint vs. Roll on for Axles HighFive Jeep CJ Forum 16 07-11-2009 07:10 PM
how to mix paint to spray from gun petey156 Jeep CJ Forum 9 09-04-2008 06:37 AM
Where can I find Spray Paint for my 86 CJ qwert98 Jeep CJ Forum 4 03-14-2008 01:42 PM
Spray paint? jeepsarecool Jeep CJ Forum 5 07-14-2004 04:07 PM
