Spray in bedliner > You Do It - Page 3 - JeepForum.com
post #31 of 355 Old 04-30-2008, 04:34 PM
jbramble24
The Raptor stuff looks like exactly what I have been looking for. Professional applications (Line-x, Rhino) are running around $700-800 from my local dealers. I have been looking into the Herculiner but it looks way too rough and hard to clean.
Is it easy to clean? How much texture does it have?
How does it work with masking off areas and then removing the tape? Easy as long as it is removed shortly after the liner is applied?
How thick of a coat did you end up with?
What solvent/cleaner do you use with it?
Thanks and yours looks great!
jbramble24 is offline
post #32 of 355 Old 05-02-2008, 10:13 AM Thread Starter
turpehar
1977 CJ5
I just hose it out. If I want it really clean I use a soft bristle brush with soapy water.
It has a much as you want. The distance from the contact of the surface and the gun can make a difference in how rough/smooth it turns out.
I removed the masking tape as soon as I could touch the spray without any sticking to my finger. Try that on the masking tape. Always pull your tape away from the edge, not toward it.
Yes, easy.
That depends on how many coats you want to put on. I used three of the four litre bottles and it seems about half as thick as the Rhino liner in my wifes truck. But I won't be hauling wood with it either
Laquer thinner is your best friend here. Please wear latex gloves and a filtered painting mask. This stuff is basically the same as Urethane auto paint. If you get it on your skin get it off asap. I used a cloth dampend with laquer thinner (OHSO wasn't watching). If it totally dries on your skin it will take a good week for it to come off no matter what you do. You can only rub so hard.
I hope I answered you questions. This is a job you can do, no problermo~
Please send pic's of your process and tell us your tricks.
I've been married so long I don't bother looking
both ways before crossing the road.
(Trial + error)*Upgrades) - $ = (mac-n-cheese/hot dogs)+experience
turpehar is offline
post #33 of 355 Old 05-02-2008, 10:44 AM
jbramble24
Thanks alot for the info. This looks like a great product. I don't want the rubbery feel and texture of the Herculiner. I may go ahead and use all four of the bottles for a slightly thicker coat in some areas but like you said, I won't be hauling wood in it either, just a couple of hounds! It may be a couple of months but I'll post some pics when I do it.
post #34 of 355 Old 05-02-2008, 09:39 PM Thread Starter
turpehar
1977 CJ5
As new as your rig is, you could probably do it in a day. It took me four evening but I spent a lot of time working over some fiberglass issues.
Strip the interioir parts that cannot be covered.
Wash with soapy water
Use a grease/wax/silicone remover on parts to be covered.
Sand with 100 grit dry paper
Mask
Shoot
When your done, you'll be a pro
turpehar is offline
post #35 of 355 Old 05-07-2008, 02:20 AM
rallynut78
thanks for the write up this is up there on my list of mods!!!
rallynut78 is offline
post #36 of 355 Old 05-09-2008, 10:06 AM
mac5551212
I'll be U-Pol-ing my tj this weekend. I'll let you guys know how it goes and make sure to post pictures.
mac5551212 is offline
post #37 of 355 Old 05-09-2008, 10:20 AM
jbramble24
Excellent! I plan on doing mine sometime soon. I ordered my kit on Tuesday so I'm hoping it gets here soon. I'm quite interested in some pics of the liner over the top rail of the tub and also on the door sills if you plan on doing that.
Have fun!
post #38 of 355 Old 05-09-2008, 10:24 AM
AngleOfRepose
1979 CJ5
That looks great.
I'm planning the same proceedure, only I was going to use the same guy that put in my Rhino Liner in the bed of my truck. But after looking at how yours looks, I think I'll go this route.
Incredible job, thanks for the share.
If at first you don't suceed; call it version 1.0.
AngleOfRepose is offline
post #39 of 355 Old 05-09-2008, 06:47 PM
chiadog2000
1983 CJ7
Just did mine the other day and it turned out great. Couldn't be happier. I read somewhere that your supposed to retape after each application, but I left it on for all coats and the tape came off very easy. I didn't have to score it or anything. Thanks for all the tips!
chiadog2000 is offline
post #40 of 355 Old 05-09-2008, 08:23 PM Thread Starter
turpehar
1977 CJ5
I've done a few of these with Raptor and the tape always comes off clean. The key is to take the tape of as soon as the spray is tack free. Tack free means that if you touch it with your finger, none will stick to it. I test on the tape itself. Make sure you pull the tape away from the sprayed surface and back towards the tape itself.
turpehar is offline
post #41 of 355 Old 05-14-2008, 10:33 AM
mac5551212
For those of you with u-pol how scratch resistant is it and how long did it take yours to fully cure? Mine was sitting for around 3 days and I noticed that I scratched a bit off when I put on the rear seat belts, luckily it's hidden and only a small patch. I know the instructions say it takes 5-7 days to fully cure but was anyone able to notice this?
post #42 of 355 Old 05-15-2008, 05:31 AM
NCHornet
Can somebody please post a link to where I can buy this kit? I did a search on Ebay for raptor bedliner and came up with 0, searched bedliner and didn't find anything called Raptor, followed the link on the previous page of this post and I didn't see a kit that comes with a gun? They had a 4 bottle kit for $99.99 and then the gun is another $20, the OP said he paid $103 for everything. Thanks for the help.
I do have a question. I had some small rust holes in groups, I repaired these by applying patches from beneath with KBS coatings applied to all surfaces and held on with that special sheetmetal glue that body shops use. These things are on there!!!! This creates a slight dip from the inside the thickness of the floorboard material, about 1/16" of a inch. Is this bedliner thick enough to smooth these areas out or should I use bondo, or fiberglass or .....? to make a flush surface before applying the liner material. Thanks for the help.
Kevin
TJ's CJ5
1977 CJ5 4X4, Soft top
304 V8 project jeep for my
16 year old son and I
NCHornet is offline
post #43 of 355 Old 05-15-2008, 07:35 AM
mac5551212
post #44 of 355 Old 05-15-2008, 07:38 AM
jbramble24
This is where I ordered mine from. I haven't seen it for as low as $103.
http://www.tcpglobal.com/detailsupplydepot/dsd18.aspx
Depending on how heavy you apply the liner, it might smooth it out but I would hit it with some bondo first just to be sure.
post #45 of 355 Old 05-15-2008, 02:30 PM
chiadog2000
1983 CJ7
I would hit it with some bondo first. From ebay, search U-Pol, not raptor. But the prices are similar to what the others have shown. It's going to cost anywhere from $115 to $120 shipped to you.
spray in bedliner in tub, do it yourself or have it done baystrucksalvag Jeep CJ Forum 19 10-18-2010 01:28 PM
experience with spray-in bedliner wanted... Skerr Jeep CJ Forum 3 04-22-2009 12:08 PM
Spray in bedliner in Jeep bill in the hil Jeep CJ Forum 17 04-16-2008 04:51 AM
Spray on bedliner - ebay pwhit Jeep CJ Forum 12 09-23-2007 09:36 AM
Do It Your Self Bedliner tico Jeep CJ Forum 15 11-08-2003 01:53 PM
