spray in bedliner in tub, do it yourself or have it done - JeepForum.com
post #1 of 20 Old 08-14-2008, 12:15 PM Thread Starter
baystrucksalvag
1976 CJ5
if anybody has any experience in DOY liner kits, tell what ones are best and where to get them, if not i oing to have it done
baystrucksalvag is offline
post #2 of 20 Old 08-14-2008, 01:15 PM
DT5150
1983 CJ7
take a look through the paint and body section. there's some threads on it in there.
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #3 of 20 Old 08-14-2008, 01:28 PM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
This is the one I usd , very easy and I love it!
U-POL Raptor Black Spray-in Liner
Read more here
http://www.jeepforum.com/forum/showt...light=bedliner
Good luck, Rick
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #4 of 20 Old 08-14-2008, 01:45 PM
CrazyHorse6
1979 CJ7
I had my truck bed done by a Rhinoliner shop for over $500, then I did my own Jeep tub with a 1 gallon can of Herculiner from JC Whitney - paid about $70 or so - came with everything I needed. I'll tell you that after almost two years, its looks great and its really holding up. The only negative comment is the Herculiner is a little more sensitive to UV light, so it tends to fade. However, a shot of Armorall and it shines and darkens right up. Now the Rhino lining in the bed of my truck - I'm not going around shoveling gravel like you see in the commercials, and in several areas the lining is peeling up. I've actually fixed it with the Herculiner. So, its cheaper, you can do it yourself, and I have no complaints about it whatsoever - I'd recommend Herculiner.
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #5 of 20 Old 08-14-2008, 08:24 PM
JeepHammer
Running On Empty...
1973 CJ5
The 'Do It Yourself' kits work pretty well, but they don't last as long as the Professionally mixed and 'Hot' Sprayed kind.
You are looking at $75 a gallon and a $25 worth of prep stuff compared to $750 to $2,500 for the 'Professionally' done bed liners...
Depending on what you choose and how thick you have them put it on.
Personally, I buy a gallon of Xylene (thinner), a gallon of Herculiner, and a cheap siphon type sand blaster/spray gun and go to town!
The sand blaster cleans up the rusty spots, cracks, crevices and hard to reach places, then you use it to spray the Herculiner on...
A sprayed on coat takes SO MUCH less of the product to do, gets into places you can't even begin to with a brush or roller, and you can do the entire interior in about 10 minutes...
Clean up of the gun is literally siphon spraying thinner through the gun between coats...
"Touch-Up" of Herculiner is SO EASY you won't believe it!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #6 of 20 Old 08-14-2008, 08:47 PM
Fatman
Fatman's Avatar
2008 CJ7
Do it yourself!
Prep is what makes the project work.
I have about $400 invested in Herculiner and all the products, tools, etc. to do it right, but I also did the underside of the tub and we went THICK on the final coats.
Pics & write up for our herc project start at post # 298: http://www.jeepforum.com/forum/f8/project-tub-431910/
Definitely an easy project that you can feel good about when you peel the tape off.
Make sure you use the UV coat, you don't want all that hard work looking like garbage in a few months.
Thread Links:
Fatman is offline
post #7 of 20 Old 08-14-2008, 08:51 PM
bdmonist
WTF is that?
bdmonist's Avatar
1234567890
http://www.bustedjeep.com/projects/herc.asp
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift.
In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles
Coming Soon - CV Shafts, Welded Tubes, trusses
bdmonist is offline
post #8 of 20 Old 08-15-2008, 08:25 AM Thread Starter
baystrucksalvag
1976 CJ5
thanks guys i think i'll do the raptor i have D A sander, and all the shop tools as i am in salvage biz, jeephammer i will post pics of my job of wiring your HEI duraspark dist conversion, that was the easy perfomance upgrade i have ever done, i took my time and split loomed everything and tied it all up, looks good.....
post #9 of 20 Old 10-15-2010, 09:05 PM
dwdrums40385
i think i'me gonna do the inside of the tub. the previous owner did the entire bottom of the tub when he changed the transmition, and that is some pretty tough lookin stuff. one question though, how well does it hold up against heat. sometimes my floorboards get pretty hot when driving for a while. i also thought about repainting the hardtop with spray-on bedliner, what does anyone think??? any suggestions??? anyone tried it???
dwdrums40385 is offline
post #10 of 20 Old 10-15-2010, 09:12 PM
FamillyCJ7
1983 CJ7
My first choice is Monstaliner. There are others I was looking at until I got interested in them and seeing how helpful they are to their customers. Customer service is number one in my book and they stand behind their products which is why I am using them on my frame up build. Monstaliner.com or you can check in the Vendor section as there is an extensive thread.
Request Sample Panel and Information Here
'83 CJ7 258I6 4-Speed Father Daughter Project - Using Monstaliner/Chassis Saver and Products from CrabTreeTool
NorthEastFL4x4.com - Local 4x4 Enthusiasts website, join up now!
FamillyCJ7 is offline
post #11 of 20 Old 10-15-2010, 09:56 PM
Eaallred
For the really budget minded, Rustoleum makes a roll on bedliner that costs about $15 a quart. I lined the entire inside of my CJ with it (bought a $2 foam roller from Lowes to do it and a brush for the corners) and it is holding up incredibly well. My jeep is a pile of crap so I figured I didn't care, but after a full summer of beating it up it is all still holding in place. Truth be told, I didn't even do any prep work other than clean the surface with brake cleaner.
A "temporary solution" that has ended up working awesome for me.
Eaallred is offline
post #12 of 20 Old 10-16-2010, 10:32 AM
dwdrums40385
now that is what ime talkin' bout!!! $15 bucks and a couple a hours of work. i think thats what i'me gonna do. i hear all these people talking about their $800 dollar bedliners, heck if ur gonna spend that much, just wait till ur tub rots to the ground and find another on craigslist or somethin. does it work pretty good, no chunks chipping out or anything. i think im headin to wally mart here in the next couple a hours
post #13 of 20 Old 10-16-2010, 04:33 PM
rustedcustom
1983 CJ7
My tub is pretty bad so after replacing about 75% of it with 16 gauge galvinized sheet metal . . . I shot it with 3 coats of Rustoleum Rubberized Undercoating out of a spray can and topped it with flat black Krylon spray paint. According to the can . . . it will stay flexible and won't crack. Works for me. . time will tell.
America Reborn November 6, 2012
My Baby is a cold blooded b****
Carter BBD ( The 8th Wonder of the World )
rustedcustom is offline
post #14 of 20 Old 10-16-2010, 06:21 PM
dwdrums40385
thats a great ideal! bed liner + spray paint = invincible. now that is a heck of a combination! thats almost as good as DUCT TAPE + SUPER GLUE. and if those don't work... well, UR SCREWED! temporarilly until you find a better solution. i think i'me gonna try that too, sounds pretty tough! also, love the picture of bubbles
post #15 of 20 Old 10-17-2010, 06:44 AM
rustedcustom
1983 CJ7
I'm glad a few people reconize Bubbles . . if they bring the series back . . they need to get Ricky sleeping in a CJ with Conky mounted to the hood. Back to the thread . . . I'm a realist . . I need a new tub but want the one I have water tight for the winter and that did the trick. Next spring. . body off replacement . . missed a metal tub at a swap meet for $350 by a half hour.
Everyone says glass. . but I don't want to live forever.
Spray in bedliner > You Do It turpehar Jeep CJ Forum 351 07-06-2016 05:44 PM
experience with spray-in bedliner wanted... Skerr Jeep CJ Forum 3 04-22-2009 01:08 PM
Spray in bedliner in Jeep bill in the hil Jeep CJ Forum 17 04-16-2008 05:51 AM
Spray on bedliner - ebay pwhit Jeep CJ Forum 12 09-23-2007 10:36 AM
Do It Your Self Bedliner tico Jeep CJ Forum 15 11-08-2003 02:53 PM
