spotty driveway oil... - JeepForum.com
post #1 of 4 Old 10-11-2013, 04:50 PM Thread Starter
TheLaw360
1982 CJ7
So I got leaks here and there... but a decent amount of fluid from here
what should i do?
TheLaw360 is offline
post #2 of 4 Old 10-11-2013, 04:54 PM
hp_lovecraft
1981 CJ5
Probobly a leaky valve cover. Oil tends to pool at the back, then drip down around the bellhousing. Easy enough to replace the seal, though check that the valve cover itself is not warped. Sometimes people think that overtightening the cover will stop a leak, and it just warps the cover.
Could also be the Rear main seal. More work involved, but no special tools or skills. Even less likely is the trans input shaft seal.
hp_lovecraft is offline
post #3 of 4 Old 10-11-2013, 07:11 PM
CSP
Find the leaks and fix them?
Clean the oil off the driveway?
Maybe you should do nothing. It depends on what you're trying to accomplish.
This is sarcasm if it isn't obvious.
CSP is offline
post #4 of 4 Old 10-11-2013, 07:25 PM
mattlago
I park on a plywood sheet and keep an eye on fluids. I will get to the leaks when I get to them. Seems like a damn that i dont have enuff fingers for.
behold a pale horse: and his name that sat on him was Death, and Hell followed with him...
2012 JKU RUBI PALE TAN
mattlago is offline
