Spindle Bearing and Seal Kit - JeepForum.com
post #1 of 10 Old 08-22-2013, 10:43 AM Thread Starter
dirtdudeaz
1983 CJ7
Hello Again...
I see various kits for the Dana 30. Currently I have the Timken SBk1 which comes with 3 pieces (bearing, bearing seal, and the angled rubber seal)
http://www.summitracing.com/parts/TMK-SBK1/
My question is in all the write-ups, I see there are some kits with 4 pieces and some with 5. Which one do I need, or is the one I have acceptable? I know the bearing goes in and then the smaller 2 lip seal. The other 1 or two pieces is what goes on the axle and the presses against the back of the spindle. Do I need 1,2,3 extra pieces!?
http://www.napaonline.com/Catalog/Ca...BK1_0247142461
http://www.jeep4x4center.com/spindle...t-8127356.html
dirtdudeaz is offline
post #2 of 10 Old 08-22-2013, 10:51 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
i dont know what is in the other kits but my SBK1 from AA was a 3 piece as you mentioned and unless something was missing prior to me taking it apart, 3 pieces were all i needed.....
the napa one you reference looks more like a pinion set up with a slinger ring....
the correct napa would be
http://www.napaonline.com/Catalog/Ca...BK1_0329276787
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #3 of 10 Old 08-22-2013, 11:00 AM
ASteve
1972 CJ5
I used the SBK-1 on my Dana 30.
Here's a quick peek:
ASteve is offline
post #4 of 10 Old 08-22-2013, 11:07 AM Thread Starter
dirtdudeaz
1983 CJ7
I see, so was the thrust washer separate from the kit?
Is that what you're holding in the second picture or is the thrust washer the piece with the conical? If that is not the piece you're holding, then was it bought separately?
EDITED!! I think I answered my question after looking at some of the parts sites. If you buy the 2nd two kits they come with the thrust washers. If you by the Timken, then you need to get a separate thrust washer.= from quadratec or jeep4x4center
post #5 of 10 Old 08-22-2013, 12:28 PM
ASteve
1972 CJ5
Hmnmm...I thought the thrust washer came with the SBK-1 kit...not sure now...but yes, I am holding the thrust washer in pic #2.
SC
ASteve is offline
post #6 of 10 Old 08-22-2013, 02:51 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
interesting..... I have never had a thrust washer.... not sure what purpose it would serve in this application......ideas?
post #7 of 10 Old 08-22-2013, 03:18 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The thrust washer is simply a plastic disk that keeps the metal parts on the axle from contacting the metal parts on the spindle. It rides on the stub axle inside (under) the bellows seal and should be part of the kit (we always used the BK1) which would include the outer bellows seal, inner spindle seal, and the bearing.
jeepdaddy2000 is offline
post #8 of 10 Old 08-22-2013, 04:31 PM
Renegade82
1982 CJ7
My kit from NAPA (SFK's BK1) had 5 pcs. like the link you provided and looked like Asteves pics. The spindle bearing, it's seal, the rubber lipped seal, the plastic thrust washer, and the metal stone shield.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #9 of 10 Old 08-22-2013, 06:47 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
hmmmm.........
post #10 of 10 Old 08-22-2013, 08:52 PM
Sean_Cj7
1982 CJ7
So glad you guys posted this, ordered a new spindle, & spindle bearing & seal kit from Morris & hope to be installing this weekend.
Sean
Sean_Cj7 is offline
