Spicer 5-760X Ujoints - JeepForum.com
post #1 of 3 Old 06-03-2013, 10:25 PM Thread Starter
CJ7KAHUNA
Looking throug some threads here and over at Pirate4x4 the Spicer 760x seems to be the favorite D30 axle ujoint upgrade. Will the Spicer 5-760x work with my 85 CJ7 D30 axles?
CJ7KAHUNA is offline
post #2 of 3 Old 06-04-2013, 09:05 AM
jurgen24
It is a larger ujoint with bigger caps. You will need new axle shafts. I just installed G2 axle assembly (from 4 Wheel Parts), its a chrome-moly shaft with Spicer 5-760x. Its a *real* tight fit getting through the knuckle (which I filed a little).
jurgen24 is offline
post #3 of 3 Old 06-04-2013, 09:26 AM Thread Starter
CJ7KAHUNA
Originally Posted by jurgen24 View Post
It is a larger ujoint with bigger caps. You will need new axle shafts. I just installed G2 axle assembly (from 4 Wheel Parts), its a chrome-only shaft with Spicer 5-760x. Its a *real* tight fit getting through the knuckle (which I filed a little).
Is the 5-760x and the 760x the same?
