Speedometer questions? - JeepForum.com
post #1 of 4 Old 02-16-2012, 08:09 PM Thread Starter
jduress
Is there anyway to calibrate your speedometer? It is a 1985 cj7 with the t5 tranny. I realize it gets its signal from a cable but mine is off by 5mph. The reason is probably the oversized tires that were on it when I bought it. Just wondering if there is a way to adjust the speedo somehow thanks!
Joel
jduress is offline
post #2 of 4 Old 02-16-2012, 08:14 PM
VACJ7
VACJ7's Avatar
The only way to compensate for the bigger tires is to change the speedo gear.
If you have a GPS it is pretty easy to calculate. You only need three things: Tooth count of gear that is currently installed, Speedometer reading, and GPS reading. Run it up to 45 or so and record speedometer reading and GPS reading. I do it at a couple different speeds.
X= speedometer reading / GPS reading
New gear = X * current tooth count
'84 CJ-7 |
VACJ7 is offline
post #3 of 4 Old 02-16-2012, 09:59 PM
only in a jeep cj
The speedometer is a set calibration from the factory and requires much know how to adjust it, but that is not the correct solution in your case. As said, the speedo gear in the transfercase is the solution. It is under where your cable screws in to the rear section. 1985 with a T5, you most likely have a 31 tooth gear and will need one a few teeth less so it spins a tad faster and bumps up the speedo.
http://www.transmissioncenter.org/sp...e_and_jeep.htm
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #4 of 4 Old 02-17-2012, 06:18 AM
lucdog
lucdog's Avatar
1980 CJ5
I believe this same place sells a adapter that has different ratios. While more expensive ($65) they do work, its installed on the TC externally, the cable then screws into it. They do work well, I have 2. One of them has 40,xxx miles on it.
They are avaible in different ratios.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
advice help , cj7 , speedometer calibration
Speedometer GO-NOLES84 Jeep CJ Forum 40 09-25-2012 10:16 PM
2 questions--shaky speedometer & bad distributor mytjtoy Jeep CJ Forum 3 12-30-2011 09:14 PM
Speedometer cable questions. Cutlass327 Jeep CJ Forum 1 12-12-2010 12:58 PM
speedometer ?? 84jeepcj7 Jeep CJ Forum 14 03-01-2007 09:25 PM
