Speedometer light bulbs - Page 4 - JeepForum.com
post #46 of 51 Old 12-31-2013, 09:50 PM
frhrwa
Fish'n Fool
frhrwa's Avatar
the face on that guage must come off. I've seen guys put that white guage decal on the face so they had to get inside somehow. otherwise, maybe picking up another speedo?
I want to die in my sleep like my grandfather, not screaming in terror like the passengers in his JEEP!...
frhrwa is offline
post #47 of 51 Old 01-01-2014, 09:50 AM
Bubba Ray
How do you get to the face?
Bubba Ray is offline
post #48 of 51 Old 01-01-2014, 02:14 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by Bubba Ray View Post
I have a slightly different problem. There seems to be plenty of light behind the face but the face itself seems to have fallen towards the glass leaving me with ok light at the bottom but almost none at the top. As anyone seen this before?
Maybe some of the bulbs burnt out?
Did the face actually fall towards the glass or is it just an illusion because of the lighting?
John Strenk is offline
post #49 of 51 Old 01-01-2014, 03:39 PM
zillla
1930 VJ
Pull the speedo and bend the tabs on the back.
Pull my finger
zillla is offline
post #50 of 51 Old 01-02-2014, 03:56 PM
Bubba Ray
Fairly sure that face has moved towards the glass. Will pull it and see.
post #51 of 51 Old 01-02-2014, 05:11 PM
SouthernGypsy
De Oppresso Liber
SouthernGypsy's Avatar
One thing we used to do was to just totally remove the green diffusers if you happen to be in there, so all of the light from the bare bulb gets out, the white background inside the housing acts as a diffuser/reflector by itself.
The back-lighting will be white instead of having a greenish tint but it's a lot brighter. Even if you want a green tint then you can buy modern bulbs with the green coating. They are still diffused with the coating but brighter than a clear bulb going through one of those diffuser covers, you can even change colors easily that way such as to red which is better at preserving your night vision if your deep offroad at night where there are no city lights.
I know this isn't a fantastic quality picture (iPhone 5s in total darkness) but the other day I took the oil pressure gauge out of our Laredo and put it into our Limited and while I had it out I reached in and popped the diffuser loose, then with a pair of long needle nose pliers I crushed it and withdrew the pieces through the hole so I wouldn't have to open up the gauge. Then I bought a new bulb but that had a green coating from the local auto parts store to use with it. This is what it now looks like next to the alternator gauge (I plan on doing all of my gauges) which is still using the diffuser with a white bulb...
_
~ SouthernGypsy's Jeeps ~
2004 Jeep TJ Rubicon 4.0L/Automatic
1983 Jeep CJ-7 Limited 4.2L/5 Speed
SouthernGypsy is offline
