Speedometer light bulbs - Page 2 - JeepForum.com
post #16 of 51 Old 11-06-2013, 10:50 AM Thread Starter
TRUVOL
http://i.ebayimg.com/t/1976-1979-Jeep-CJ5-CJ7-85-Mph-Dash-Cluster-White-Face-Gauges-76-79-/00/s/MzA1WDM5OA==/$(KGrHqN,!lMF!i,Iee7RBQW8OQ4mtQ~~60_12.JPG Saw this on ebay
TRUVOL is offline
post #17 of 51 Old 11-06-2013, 11:02 AM Thread Starter
TRUVOL
Other instructions
TRUVOL is offline
post #18 of 51 Old 11-06-2013, 11:09 AM Thread Starter
TRUVOL
Looks like you can get these in different colors. Has anyone done this? Kit is 20 dollars.
TRUVOL is offline
post #19 of 51 Old 11-06-2013, 11:12 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Originally Posted by TRUVOL View Post
John I really like the top picture. How was that done?
http://www.earlycj5.net/forums/showt...meter%20lights
I wonder if you can get those sheets and run them through a laser printer to make your own
John Strenk is offline
post #20 of 51 Old 11-06-2013, 11:25 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
Originally Posted by lucdog View Post
I would run a Dedicated ground to one of the nuts that hold the speedometer in the dash. This would run from battery Negative , or a central grounding point that is direct to the battery negative.
Bill
This was my first thought....
2Xtreme is offline
post #21 of 51 Old 11-06-2013, 11:38 AM Thread Starter
TRUVOL
John I thought those were seperate pics. Why is the one pic dimmer than the other ones? I guess its just the angle the pic was taken huh?
TRUVOL is offline
post #22 of 51 Old 11-06-2013, 11:39 AM Thread Starter
TRUVOL
I dont know but for 20 dollars for all the gauges is pretty good. I'm not that cheap.
TRUVOL is offline
post #23 of 51 Old 11-06-2013, 01:46 PM
ScroungerLee
I have wondered if a black light setup is possible so that just the numbers and needles glow. Black lights put out a little bit of purple visible light which wouldn't look bad to me. I should hunt around to see what's available.
ScroungerLee is offline
post #24 of 51 Old 11-06-2013, 02:22 PM
bradleybrb
1975 CJ5
I did the white face on mine and I really like it. I used the green leds. It shows up really good at night. I don't have a pic with them lite up but here is how they look.
bradleybrb is offline
post #25 of 51 Old 11-06-2013, 06:41 PM
keith460
Jeep. There's Only One
keith460's Avatar
The white facing for the gauges look cool and would stand out much better than the OEM black facing. But, ripping apart tachometer, clock, oil pressure and voltage gauge... forget that! I had a hell of a time just trying to get the chrome ring off the clock so I could replace the yellowed over ABS cover so I could replace it.
1984 CJ-7 Renegade
keith460 is offline
post #26 of 51 Old 11-06-2013, 06:51 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Something that no one has mentioned (unless I missed it which is entirely possible) is to open up the speedo housing and clean the dust off of the plastic lamp diffusers. I don't think it'll make a night and day difference, but it can't hurt. Mine was a bit brighter after doing that.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #27 of 51 Old 11-06-2013, 07:49 PM Thread Starter
TRUVOL
I just did that to mine but no difference. I think I'm gonna have the back inside casing powder coated white. My gas tanks skid plate is getting powder coated anyway.
TRUVOL is offline
post #28 of 51 Old 11-06-2013, 08:03 PM
Skerr
I had painted the front blinker housings with silver metallic paint. They are so bright with the factory bulbs they look like LED.
Does the LED strip light it up so bright that it looks like the high beams are on?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #29 of 51 Old 11-06-2013, 08:05 PM Thread Starter
TRUVOL
Is it really visible at night? Looks great. I'm thinking of doing the orange overlay(being a tennessee fan).LOL A night pic would be cool. Also did you get the 4 point ba9 bulbs from them?
TRUVOL is offline
post #30 of 51 Old 11-07-2013, 04:07 AM
John Strenk
1976 CJ5
Good point, That looks like a light leak because there is a tube over it so it shouldn't get illuminated.
High beams are usually blue but IF you put in a different color, that might help.
