Speedometer light bulbs - JeepForum.com
post #1 of 51 Old 11-05-2013, 01:25 AM Thread Starter
TRUVOL
A long time ago i replaced the bulbs in my speedometer. The lighting is terrible. Is there something I can do make it brighter? Just curious to see what other people have done or would suggest. Thanks
TRUVOL is offline
post #2 of 51 Old 11-05-2013, 01:39 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Just checking that you're aware the headlight switch has a dimmer for the dash lights.
Matt
Matt1981CJ7 is online now
post #3 of 51 Old 11-05-2013, 01:49 AM
Spieg8
1984 CJ8
I think the design of the gauges really limits what you can do to improve the illumination (backlit gauges would be awesome, but not realistic to do). About the best you can do is replace the incandescent bulbs with LEDs (still relies on reflective lighting, but at least a bit brighter).
Having said that, there are some excellent aftermarket gauges that fit the stock dash very nicely and provide more modern lighting technology. They are also pretty expensive (beyond my budget anyway).
Spieg8 is offline
post #4 of 51 Old 11-05-2013, 01:49 AM Thread Starter
TRUVOL
Yes it does. Brand new one.
TRUVOL is offline
post #5 of 51 Old 11-05-2013, 01:51 AM Thread Starter
TRUVOL
Do you know the bulb numbers to change over to LEDs.
TRUVOL is offline
post #6 of 51 Old 11-05-2013, 08:16 PM
Spieg8
1984 CJ8
They are a #53 bulb. Here is an example of an LED replacement;
http://www.martekled.com/-strse-186/...amp/Detail.bok
Spieg8 is offline
post #7 of 51 Old 11-05-2013, 10:10 PM
ThisGuyUKnow
Im speaking from a position of experience. I tried using LEDS and it was actually harder to see than with the regular bulbs... No idea why but LEDS don't reflect very well. The LEDS made the back light portions like the bright indicators and directional signals brighter but didn't improve the speedo face illumination.
1985 CJ7 Laredo, 4.0, NV3550, D300, 3.31 AMC 20 w/trac loc
ThisGuyUKnow is offline
post #8 of 51 Old 11-05-2013, 11:08 PM
Spieg8
1984 CJ8
LEDs are by nature a much more directional light source than incandescent. If you use the bulbs with a built in diffuser, it's much better in this type of application. My speedometer is much easier for me to read now than with stock lighting.
Spieg8 is offline
post #9 of 51 Old 11-05-2013, 11:20 PM Thread Starter
TRUVOL
Gotta pic
TRUVOL is offline
post #10 of 51 Old 11-05-2013, 11:24 PM Thread Starter
TRUVOL
Should they all be #53
TRUVOL is offline
post #11 of 51 Old 11-06-2013, 04:19 AM
John Strenk
John Strenk's Avatar
1976 CJ5
This is probably what I'll do next:
http://www.earlycj5.net/forums/showt...meter%20lights
I saw these lights at autozone.
I wouldn't use those gauges though...
John Strenk is offline
post #12 of 51 Old 11-06-2013, 06:03 AM
lucdog
1980 CJ5
I would run a Dedicated ground to one of the nuts that hold the speedometer in the dash. This would run from battery Negative , or a central grounding point that is direct to the battery negative.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #13 of 51 Old 11-06-2013, 06:45 AM
keith460
Jeep. There's Only One
keith460's Avatar
I used the LED's for a short period of time in the Speedometer, changed the look of the lighting to a point that it did not match the OEM look. Instead of a greenish OEM light output, it became much whiter and to me it didn't look right so I removed them. Plus, they really didn't make the face of the Speedometer brighter for viewing either.
I was thinking of removing the Speedometer housing and either painting the inside white or powder coat it in 'reflective chrome'. I think I have seen someone on here that has painted the inside of the housing white before.
1984 CJ-7 Renegade
keith460 is offline
post #14 of 51 Old 11-06-2013, 08:27 AM
John Strenk
1976 CJ5
Just leave an open spot for the grounds.
I think the white paint was used on the turn signal housings or tail lights.
Worked well
post #15 of 51 Old 11-06-2013, 10:44 AM Thread Starter
TRUVOL
John I really like the top picture. How was that done?
TRUVOL is offline
