Quantcast Speedometer gear in Dana 20? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Speedometer gear in Dana 20?
Spartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-RoadBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 02-05-2007, 08:35 AM   #1
Matt in TN
1979 CJ7
I keep reading about changing the speedometer gear in newer Jeeps like it's a simple swap. I pulled the output section of my Dana 20 off yesterday for something else and it looks like I'd be pressing bearings and seals out to change anything inside there. Am I missing something or is this much worse on a CJ?
Join an off-road club! [URL="http://www.cumberlandoffroad.com"]http://www.cumberlandoffroad.com[/URL]
[B]'79 CJ-7, 304, T-18a, Dana 20, AMC-20 w/ Yukon 1-piece axles, and Dana-30, 33x12.50x15, 1" Body Lift w/ heavily trimmed fenders, full cage with seats and harnesses, CJ/Wagoneer power steering upgrade, custom front and rear bumpers, body armor, and belly-up skidplate[/B]
In the garage, waiting for hell to freeze over so I can finish the installation: Waggy front D44, AMC M23 rear
Matt in TN is offline   Reply With Quote
Old 02-05-2007, 06:47 PM   #2
mud4me
No need to "press" anything out of the Dana 20.
It's been about 18 months since I did mine, and I can't remember what I did, as it was rather simple and to othe point (that is if you're somewhat mechanically inclined)
Loosen some screws and bolts. Tap here. Tap there. And It's apart.
I did need an extra set of hands for a portion or two of re-assembly.
86 CJ-7, 360, Holley Avenger, T-18, Dana 20, 4" suspension,
mud4me is offline   Reply With Quote
Old 02-05-2007, 10:02 PM   #3
whit450
1977 CJ5
This is straight out of the Jeep CJ Rebuilder's Manual.
At rear bearing cap, remove the clamp for the speedometer drive gear housing. Note the notches on the top of the speedometer housing. The shaft offset can be positioned to fit a variety of driven gear diameters. When adjusting speedometer ratios for oversized tires and axle gearing changes, this housing design is very useful.
This was for a Dana 300, hope it helps ya out.
whit450 is offline   Reply With Quote
Glock Forum
