Quantcast Speedometer Gear Change Help! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Speedometer Gear Change Help!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire Carrier4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed
Old 03-18-2008, 04:05 PM   #1
RrCoX22
For an '82 CJ-5 with 300trans./case
Swapping from 2:72 gears w/31" tires to 4:10 gears w/33" and need to adjust the speedo and does the inner drive drive gear need to be changed? Have the dark green gear right now and need to know the process to line this up correctly.
[FONT="Impact"][SIZE="3"]1997 5.2L [COLOR="Red"]ZJ[/COLOR] [COLOR="DimGray"]Limited[/COLOR][/SIZE][/FONT]
[URL="http://www.norcal4x4forum.com"]Norcal 4x4 Forum[/URL] | [URL="http://www.fquick.com/RrCoX22"]My Garage[/URL]
RrCoX22 is offline   Reply With Quote
Old 03-18-2008, 04:20 PM   #2
yellow85cj
yellow85cj's Avatar
Speedo gear size app http://www.jeeptech.com/javaAps/Speedo.html
Size/color chart http://www.greatcj8.com/speedogear.htm
Gear teeth number is molded into bottom of the gear as there seem to be 2 green sizes on the chart.
Line the gear number that you have (marked on the gear housing) with the arrow on the shaft housing. It is cast into the housing but hard to see on an oily 300. It is marked in red in the pic.
yellow85cj is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
