Speedometer gear after gear change
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
Well just regeared now I need a new gear for my speedometer. I know I'm not doing 90. Where can I buy one? It's the one that is no the tranny. Thanks
1980 CJ 5. Hummer Yellow. SS dash, Rhino Lining 258 23 Gal gas tank Rock bumper Fnt & R. 8000# Ramsey Patriot Winch. Painless wiring. 411 gears OX rear Aussie front, dual batteries,Optima Red top, Firestone Destination M/T 33X 12.50 Sylvania Silver Star Head Lights, Rancho 9000, Superlift, Weber, KC off road lights, Cobra CB, DUI ignition etc $$$$. |
#2 |
It's actually on the Transfer case and I got mine at a Chrysler dealership.
----------------------- I used to own a CJ....:-( http://www.bustedjeep.com AIM: Qsting68 |
#3 |
I regeared last year and looked into getting new speedo gears. No luck. I have a 80 CJ-5 with the short tailshaft 300 transfer case. The later ones with the long tail shaft use different gears. A guy at a speedometer shop said he can fix me up with a reduction gearbox that goes between the transfer case and speedo cable. I've been sitting on it since I plan to change tire sizes sometime this year. Can't decide between 32's or 33's so until I decide, I just try to keep up with the normal flow of traffic.
#4 |
I wonder what I have, probably a short shat as well. I'll keep looking, I wonder if a dealer would have a part for a vehicle this old.
#5 | |
If I ever change tire size or ratios again it can be recal. and cost even less.
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust I'm not as good as I once was....but I'm good once as I ever was. |
#6 |
crash and burn,
i had no idea we had all these 80 cj5 short d300's here! great, i was just thinking the other night about how to recalibrate my ratio in my 80 cj5. do you have pics of this converter box they installed and maybe a brand? |
#7 | |
#8 |
Check out this link:http://www.transmissioncenter.net/speedometer_calibration_______va.htm
Under the GM Ratio adapter section. Is this what your talking about? Which one did you use??
#9 |
I ordered gear today from dealer. But I'm doubtful it is correct. Data base only goes to 83, we'll see.
#10 |
Picked up gear today. JADAMS68 is was your gear about 4 1/2 inches long?? Bigger than I thought. I hope it fits. How did you take it out?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
