Quantcast Speedometer Gear - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Speedometer Gear
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Old 07-31-2005, 11:44 PM   #1
pf1130
Speedometer Gear
Hey guys,
Finally got the 33's on the CJ and am looking to change the speedo gear to make it read accurately. Anyone know which speedometer gear i need for 4.11 gears? The tires are Pro Comp M/T's dunno if they run small or not. Also any tips on installing the gear? Part #'s would be great too. thanks in advance guys.
1985 CJ-7, I6-258, T-176, 1" Body lift, Weber 38/38, 1 piece Superiors, 4.11's, RE 2.5" Lift, Doetsch Tech Shocks, KC HiLites, TFI Ignition, 33" Pro Comp M/T's, TSM Rear Disc Conversion, and too many replacement parts,...
pf1130 is offline   Reply With Quote
Old 08-01-2005, 07:40 AM   #2
gosupes
Your best bet would be to go to a trans shop. They will calculate what you need and probably have one in stock.
http://www.jeeptech.com/javaAps/Speedo.html
1986 CJ7, 4.2 w/4.0 head, TFI-HEI hybrid ignition, Clifford manifold w/Holley 390 w/cold air intake, OBA (in work), 150 amp alt., 4.5" lift, Woody CV shaft, 4.10 gears - lunchbox in front, Truetrac in the back, twin-sticked, blower upgrade for running topless, keepin' it simple.
gosupes is online now   Reply With Quote
Glock Forum
