Speedometer - JeepForum.com
post #1 of 6 Old 12-02-2013, 09:48 PM Thread Starter
leewong69
1977 CJ7
Speedometer
What would cause the needle on the speedometer to move from side to side and not show me the speed I'm going while I'm driving.
Thanks in advance for the help.
leewong69 is offline
post #2 of 6 Old 12-02-2013, 10:07 PM
fourbtgait
1930 MK Patriot
Cable hanging up inside the sheath.
Either has a kink or needs greased.
fourbtgait is offline
post #3 of 6 Old 12-02-2013, 10:37 PM Thread Starter
leewong69
1977 CJ7
Can I take the cable apart or do I need to replace.
post #4 of 6 Old 12-02-2013, 10:45 PM
fourbtgait
1930 MK Patriot
You can pull it out of the sheath, see if the grease is old, dry. Possibly flush it out, regrease it, slip it back in.
post #5 of 6 Old 12-03-2013, 01:30 AM
BagusJeep
1981 CJ7
Also caused by wear in the cable and loss of rigidty of the inner core and inappropiate routing with bends of less than 6" radius.
As said can be taken apart and regreased but use a lithium white grease and wipe off the last few inches. This MAY help.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 6 Old 12-03-2013, 08:10 AM
WindKnot
1977 CJ7
If all else fails a new one is $10-$15. Just measure for the right one!
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
