speedo gear - JeepForum.com
post #1 of 5 Old 02-04-2013, 08:37 AM Thread Starter
charlesgreatmax
1977 CJ5
speedo gear
how do i change speedo gear inside transfer case
charlesgreatmax is offline
post #2 of 5 Old 02-04-2013, 09:28 AM
MoC
Do you have a replacement speedo gear yet?
MoC is offline
post #3 of 5 Old 02-04-2013, 10:47 AM Thread Starter
charlesgreatmax
1977 CJ5
No cant find one 15 tooth cj5 can mine be slipping
post #4 of 5 Old 02-04-2013, 10:56 AM
CSP
The gear could be bad or the cable could be bad. Until you remove the cable from the gear housing you'll never know. You need a thinwall socket to get to the driven gear.
Edit: Assuming D20 tcase given '77 CJ5 in profile
CSP is offline
post #5 of 5 Old 02-04-2013, 11:14 AM
Renegade82
1982 CJ7
You didn't specify which tcase so I'll assume the Dana 300. Remove the gold bolt and clamp shown in the top pic. Pull this out. You may have to twist it some, it has a rubber O-ring on it so a little 3in1 may help. This will expose your "driven" gear. You'll have to look in the hole to see your "drive" gear.
If your going to change the tooth count to correct your speedo reading, that's another issue with additional cautions and calculations must be done. But just ask and JF will help.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
