Speedo Gauge - JeepForum.com
post #1 of 8 Old 01-13-2008, 08:53 PM Thread Starter
PODNA
Speedo Gauge
I Am In The Process Of Replacing My Speedo Because My Fuel And Temp Gauge Did Not Work. I Have Replaced The Speedo And When I
Turn Ignition On The Temp Gauge Pegs Out. I Have Also Located My Sensing Wire Under Hood And Have Ohmed It Out Good
No Breaks But I Try To Use My Test Light They Say That It Should Blink Well I Get Nothing. They Also Say That You Can Use Your Dvm
And Touch A Terminal Of The Temp Gauge And You Should Get Pulising About 5 Volts If It Reads 12 Volts The Jumper Strip Is Bad?
Well I Get 5 Volts Until The Gauge Pegs Out Then I Get No Volts??
I Inspected The Jumper Strip But That Is Metal How Can That Go Bad
Or Is There Another Jumper Strip??
Could Someone Please Help I Feel That I Am Close..
Thanks For Your Time
PODNA is offline
post #2 of 8 Old 01-14-2008, 05:14 AM
John Strenk
John Strenk's Avatar
1976 CJ5
IF you have a bad ground to the speedo housing then the regulator will not work and you will see the gauges pegging. That is not good for the gauges.
Also make sure you did not switch the sensor wire and the power wire. The red wire should go to the "I" terminal and the Fuel sender should go to the "S" terminal.
Take your test light and connect the lead to the + terminal on your battery and then touch it to the back of the speedo housing. It should light up if it's properly grounded.
You might have to pull the fuse for the instument lights. Why? Because the ground can back feed thru the bulbs to a differnt ground that will go away when you turn your lights on.
The jumper strip cannot go bad. Like yousaid. it's just a metal jumper. The regulator is inside the the fuel gauge. That can go bad or a bad ground can make it not work.
http://users.adelphia.net/~john.stre...eQuickTest.htm
http://users.adelphia.net/~john.stre...au.htm#Grounds
http://users.adelphia.net/~john.stre...QuickFacts.htm
John Strenk is offline
post #3 of 8 Old 01-14-2008, 09:46 AM Thread Starter
PODNA
okay thanks i will check out my grounds
second i just wanted to visit with you on some other issues that i have seen.
i have found your troubleshooting guide over the weekend and wanted to ask some more questions about it and it may bring up some more comments.
i used my test light and put it on the i terminal and i got a solid light
then i touched the a terminal on fuel gauge and i got a full flash like you said then i . then i touched the s terminal and i got a flash but it was dimmer like you said. so then i found my wire under the hood for the temp sending unit
and you said that i should get a blinking light at that point also
now you are saying that i should put my test light in the wire not touching any thing else and i should get a blinking light i am not getting that
i also ohmed out the wire and it ohms out good no breaks in it ????
please explain....
PODNA is offline
post #4 of 8 Old 01-14-2008, 12:26 PM
John Strenk
1976 CJ5
Actually touching the "S" terminal on the back of the gauge should be the same as if it's right on the sensor.
I guess I'm not sure of the results.
1. Touching it to the "S" terminal with the wire disconected: Bright Flash OK
2. Touching it to the "S" terminal with the wire connected: dimm Flash OK
3. Touching it to the Sensor gives no flash: Uhmm... Are you connecting it to the correct sensor or on the right part of the sensor?
post #5 of 8 Old 01-14-2008, 03:12 PM Thread Starter
PODNA
do i need to touch the sensor or do i need to touch the inside of the wire
while it is off the sensor or do i need to touch the inside of the
wire and the sensor at the same time???
PODNA is offline
post #6 of 8 Old 01-14-2008, 03:23 PM Thread Starter
PODNA
one more question while i am doing these test my temp gauge is still pegging out is that okay as long as i do not leave it for long?? or is there another procedure that i need to follw??
PODNA is offline
post #7 of 8 Old 01-14-2008, 05:41 PM
John Strenk
1976 CJ5
It flashes but still pegs the gauge?
Both of them?
Does the gauge still peg even if the sensor wire is disconnected?
post #8 of 8 Old 01-14-2008, 06:58 PM Thread Starter
PODNA
No Only The Temp Pegs Even With The Wire Off
I Also Checke Dthe Battery Pos With Test Light To Back Of The Speedo And It Lights Up
One More Thing The Previous Owner Hooked Up A After Market Temp Gauge And They Ran A Ground All The Way From The Extra Pigtail On The Battery Negative????
PODNA is offline
TEMP GAUGE, FUEL GAUGE, AND SPEEDO HELP PlEASE cgi2099 Jeep CJ Forum 8 11-03-2009 05:49 PM
CJ Speedo and Fuel Gauge Help ncres Jeep CJ Forum 2 04-15-2009 03:32 AM
Speedo, Fuel Gauge and Temp gauge not working KYCJ7 Jeep CJ Forum 1 07-07-2008 12:41 PM
Replacement speedo gauge bulbs? supraman1990 Jeep CJ Forum 6 07-30-2007 03:52 PM
Troubleshooting Speedo Gauge/Cable? Military Jeeper Jeep CJ Forum 6 10-10-2005 03:47 PM
