Speedo, Fuel Gauge and Temp gauge not working - JeepForum.com
post #1 of 2 Old 07-07-2008, 01:29 PM Thread Starter
KYCJ7
1980 CJ7
Now that I've got my CJ running right its on to the smaller problems. First of which being is the speedo, fuel gauge and temp gauge do not work. They are all on the same cluster I don't know if that matters. I'm lost when it comes to gauges I would appreciate any help you can give. I don't mind the speedo as much as the other two because I don't want to over heat it and I sure don't want to run out of gas out in the middle of no where.
KYCJ7
KYCJ7 is offline
post #2 of 2 Old 07-07-2008, 01:41 PM
LGreevesCJ7
1977 CJ7
Check the speedometer cable and the gear in the transfer. check that the fuel tank ground wire is connected to a chasis ground and all wires are connected to back of cluster.
LGreevesCJ7 is offline
TEMP GAUGE, FUEL GAUGE, AND SPEEDO HELP PlEASE cgi2099 Jeep CJ Forum 8 11-03-2009 06:49 PM
Temp Gauge not working (atypical caps on back of speedo) cb_cooke Jeep CJ Forum 6 02-21-2009 03:46 PM
fuel and temp gauge not working stonewallmp5 Jeep CJ Forum 5 04-13-2007 09:12 AM
Temp and Fuel Gauge not working bamakrw Jeep CJ Forum 97 05-17-2005 12:30 PM
temp and fuel gauge not working? aufderheide Jeep CJ Forum 7 02-22-2004 12:03 PM
