Speed Out on torx - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Speed Out on torx
WJ Modular Recovery & Bull Bar Relocation PackagesRough Country Jeep Suspension Deals at Rockridge 4WD!Steinjager TJ tube doors
Unread 03-18-2014, 03:54 PM   #1
cj7red
Speed Out on torx
Has anyone used the speed out drill bit to get stripped torx bolts out?
I've seen it on tv for a while but wonder if it would be effective on frozen jeep bolts.
cj7red is offline   Reply With Quote
Unread 03-18-2014, 05:44 PM   #2
LumpyGrits
Cut a slot and use a big screwdriver.
What screws are these?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is online now   Reply With Quote
Unread 03-18-2014, 05:45 PM   #3
80cj
80cj's Avatar
1980 CJ5
I have a similar set of Craftsman screw extractors. works OK on things that are not frozen or rusted in too badly. Best thing to do is to use PB Blaster, heat, etc. before the torx head gets stripped out. I also found that cleaning out the torx head with a piece of wire and brake cleaner or something similar so that the torx driver bit can go in full depth is helpful. Often you stick a bit in a torx bolt head and you end up compacting whatever crud was in the bolt head so that the bit cannot get full depth engagement and you end up stripping out the bolt head.
80cj is offline   Reply With Quote
Unread 03-18-2014, 07:50 PM   #4
texasdave
texasdave's Avatar
1980 CJ7
Another tool I've had success is an impact driver. Not the air kind but one that you smack with a hammer and it rotates the bit. The vibration helps.
texasdave is offline   Reply With Quote
Unread 03-18-2014, 08:37 PM   #5
cj7red
Originally Posted by LumpyGrits
Cut a slot and use a big screwdriver. What screws are these? LG
The roll bar bolts. I'm putting a yj family roll bar in my cj7.
Unread 03-18-2014, 09:21 PM   #6
ctorj
1977 CJ7
I just drilled the center of the bolt out till the head came off. Then replaced them with new bolts. Took less than a minute.
ctorj is offline   Reply With Quote
Unread 03-18-2014, 11:24 PM   #7
80cj
80cj's Avatar
1980 CJ5
I had a difficult time with 2 of my roll bar bolts. I drilled through with a 5/16" bit then cleaned the hole out with a 3/8-16 tap. Turned out great and I was able to save the welded on nuts.
Unread 03-19-2014, 04:43 AM   #8
LeePrather
1978 CJ5
Screw extractors....
LeePrather is offline   Reply With Quote
Unread 03-19-2014, 05:14 AM   #9
hasselback
Sophisticated Red Neck
hasselback's Avatar
I turn them into hex head bolts by welding a nut on top of the head, like I did with the windshield frame hinge bolts. Works every time on the most stubborn bolts!
1984 CJ7 I6 258 Bone stock
"Screw the brakes, just make the horn louder!"
My build thread
http://www.jeepforum.com/forum/f8/ha...build-1409432/
hasselback is online now   Reply With Quote
Unread 03-19-2014, 10:08 AM   #10
2Xtreme
2Xtreme's Avatar
1979 CJ7
Cut to flats directly across from each other and use a wrench and heat/ penetrant.
2Xtreme is offline   Reply With Quote
Unread 03-19-2014, 10:26 AM   #11
80cj
80cj's Avatar
1980 CJ5
The heat from welding probably helped loosen things too.
Unread 03-19-2014, 11:10 AM   #12
hasselback
hasselback's Avatar
You bet!
My build thread
Unread 03-19-2014, 01:02 PM   #13
cj7red
Will PB Blaster have any effect on the bed liner I sprayed in my tub?
Unread 03-19-2014, 02:01 PM   #14
arkiemurph
I wouldn't think so. Unless you did it in the last few days?
Murph
Love thy neighbor, but don't mow down the hedge.
arkiemurph is offline   Reply With Quote
