Spark problem on 4.2L - JeepForum.com
post #1 of 7 Old 07-20-2013, 11:36 AM Thread Starter
JMcDonaldKnives
1980 CJ7
My buddies 81 CJ8 with 4.2L is having a problem that puzzle the hell out of me. It only sparks when he first turns the key on and when he turns the key off. New coil and ICM. Its puzzling me. Anyone else ever had this problem?
Director of Texas Jeeps Corpus Christi Chapter
My Build Threads
1980 CJ7 4.2L T177 D300 D30 AMC20 (under construction)
1989 YJ 4.2L T177 NP231 D30 D35 Pro Comp 3" lift 32/1150/15 BFG AT
JMcDonaldKnives is offline
post #2 of 7 Old 07-20-2013, 12:57 PM
CJuncky
1981 CJ5
Sounds like ignition switch to me. Test for voltage at coil with key in on position and start position.
Sent from my DROID RAZR HD using JeepForum
81 CJ5 258/T18/dana20/ARB locked diffs/33's
80 CJ7 258/auto/d 44 diffs/ 4" lift/rebuild started 80 CJ7 #2 stock(sold)
82 CJ7 stock DD
CJuncky is offline
post #3 of 7 Old 07-20-2013, 01:04 PM Thread Starter
JMcDonaldKnives
1980 CJ7
I'll have to do that when I get over there
My Build Threads
post #4 of 7 Old 07-20-2013, 02:29 PM
james04si
james04si's Avatar
1977 CJ5
And it could just be the switch is misaligned and not actually bad. They have slots for the screws and adjust for the right spot for when the key is in different positions.
james04si is offline
post #5 of 7 Old 07-20-2013, 05:46 PM
Caish
1987 XJ Cherokee
I agree sounds like a faulty ignition switch.
Or if it has tilt wheel, the switch is on the column itself and checl the alignment of the switch, they have been known to come loose and slide up or down causing the switch to be mis-aligned.
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
post #6 of 7 Old 07-20-2013, 06:24 PM
james04si
james04si's Avatar
1977 CJ5
The tilt and non tilt columns have the same type adjustable switch.
post #7 of 7 Old 07-29-2013, 05:55 AM Thread Starter
JMcDonaldKnives
1980 CJ7
Forgot to reply with what I found. Turned out to be the distributor. The shaft bearings were getting worn and causing it to hit the pickup. Replaced the distributor and it fired right up. Starts even better than it used to.
My Build Threads
