Which spark plugs on 4.2l 6cyl? - JeepForum.com
post #1 of 10 Old 08-15-2013, 09:09 PM Thread Starter
Gasman303
1979 CJ7
Ok I just gathered my Team rush distributer upgrade kit along with Msd 6al ignition module and Howell tach filter
What spark plugs work best with this setup I'm going with?
4.2l, stock motor, T5 trans, howell efi
Thanks
Gasman303 is offline
post #2 of 10 Old 08-15-2013, 09:18 PM
SCSEAJAYSEVEN
1978 CJ7
I use Autolite/Motorcraft part # 985 in mine. Set the gap at .045 to start, you can play around with this setting. I once set mine at .050, that was too much. Currently I have them set about .042-.043. Seems to work fine at this setting.
KB4ERT
1978 CJ-7 258 4.2L
1982 DJ-5L 151 2.5L
SCSEAJAYSEVEN is offline
post #3 of 10 Old 08-16-2013, 07:49 AM
Neuner-9R
I thought about doing this. What do you mean by too much? Non effective or tearing up your dizzy?
Neuner-9R is offline
post #4 of 10 Old 08-16-2013, 11:20 AM Thread Starter
Gasman303
1979 CJ7
I purchased Bosch platinum they are pre gapped .38 ill have to take it to .45 I guess?!
post #5 of 10 Old 08-16-2013, 11:35 AM
RenoF250
You can leave them at .038. I am not much of a fan of the Bosch platinums myself. Fire them outside the engine next to a regular plug and you will see they make a puny little spark.
RenoF250 is offline
post #6 of 10 Old 08-16-2013, 11:37 AM
Renegade82
1982 CJ7
I'd be careful of the Bosch plugs. I know of two people who had their Bosch plugs come apart and cause major damage and Bosch wouldn't back up their product.
I currently am using the 985 autolite's.
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (the 4 year saga....)
Renegade82 is offline
post #7 of 10 Old 08-16-2013, 04:44 PM
LumpyGrits
Bosch plugs run on the cold side.
Time 2 on Autolite 985's. I run prem(91)fuel and found that .045" gap was best all around.
LG
LumpyGrits is offline
post #8 of 10 Old 08-16-2013, 06:52 PM
WindKnot
1977 CJ7
I'm with Lumpy on this. Same set up. You're wasting your money on the Bosch or any platinum plug with your Jeep, IMO. Just a good ol' copper plug does fine.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #9 of 10 Old 08-16-2013, 08:07 PM
waterdowg
I use plain Copper Champion Plugs in all the Jeeps that I have ever owned over the past 20 years.
waterdowg is offline
post #10 of 10 Old 08-16-2013, 11:00 PM
Renegade82
1982 CJ7
Yep, I've run Champions as well. I used to get the resister ones to reduce engine static in the cb. I've been runnin' the 985's in more recent years but I never noticed much of a difference between the two, that I recall.
