Spare tire carrier question - JeepForum.com
post #1 of 5 Old 10-22-2003, 09:31 AM Thread Starter
HIPPER
HIPPER's Avatar
I am looking for a tire carrier that mounts to the frame. I don't want to spend 500 bucks on a bumper/carrier combo because I want to run a double tube bumper in the rear. I am looking into the carrier made by 4wd Hardware, however, they recomend not going over a 31" tire with their carrier. They said the weight of a 31 with a steel wheel was used as their test. I was thinking that if I run a heavier tire, like a 33x12.5 bfg mt I could make up for the extra weight with an aluminum wheel, like the MT classic II. The guy from tech told me that I should be alright and that they had to put some kind of caution on it so people don't try to mount 37's and so on.
Does anyone have any thoughts on this?
Does anyone know the weight of a 31" tire mounted on a steel wheel and a 33" mounted on an aluminum wheel?
HIPPER is offline
post #2 of 5 Old 10-22-2003, 10:07 AM
jadams68
jadams68's Avatar
Even the stock carrier can hold a 33" tire on a stock wheel. I've done it for years without any problems.
If you're not planning to wheel your vehicle (and from reading your post, that's what I'm assuming), then you don't need a beefy tire/bumper carrier system with frame tie-ins, etc.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 5 Old 10-22-2003, 10:34 AM Thread Starter
HIPPER
HIPPER's Avatar
maybe I should have added that I am running a fiberglass body. I have a stock carrier, however, I don't have the holes in the body. I don't think the body is strong enough, so I was going to make a better mounting system for the stock carrier to disperse the weight. I just thought that if I could get a aftermarket carrier for 100 bucks that would hold a 33" tire, then that would be the way to go. It would save me a lot of time making the mount and measuring for the holes and all.
Also, why did you assume from my first post that I would not be wheeling this Jeep?
HIPPER is offline
post #4 of 5 Old 10-22-2003, 11:22 AM
Greezy Gringo
Greezy Gringo's Avatar
If your skilled with a welder, or know someone who is I would check out this site.
http://myweb.cableone.net/wdohrn/carrier.htm
He has designed a really nice tire carrier that holds two jimmy cans. If I were a better welder I'd make one myself.
'87 Grand Wagoneer
'80 CJ7
Greezy Gringo is offline
post #5 of 5 Old 10-22-2003, 11:48 AM
jadams68
jadams68's Avatar
No offense intended, but when you said something about a double-tube rear bumper, I assumed you weren't expecting to wheel heavily on it.
Reason being is that the tube bumpers are not rated for towing or recovery and have no areas to easily mount tow points.
I don't know of any $100 carrier systems out there, but that doesn't mean they don't exist.
I agree with the idea of welding and/or fabbing up your own design. The link that Gringo suggested is a design for a heavy-duty tire/bumper combo.
The really heavy duty units almost always come in a combo package and more than not have frame tie-ins. Trust one who knows, without the tie-ins, these carriers bounce and rattle all over the place and put stress on the rear crossmember.
jadams68 is offline
'74 CJ5 spare tire carrier HW question Full Tank Jeep CJ Forum 2 09-18-2008 04:00 PM
OEM Swing Out spare tire carrier question ??? jatepper Jeep CJ Forum 3 11-17-2007 11:00 PM
Question on spare tire carrier mmerlina Jeep CJ Forum 12 09-02-2007 11:51 PM
Spare tire carrier Guard Bum Jeep CJ Forum 8 12-31-2006 12:30 PM
Spare tire carrier-Help tlannom Jeep CJ Forum 1 10-11-2004 10:25 PM
