Sources for GM 151 temperature sender - JeepForum.com
post #1 of 9 Old 09-21-2017, 08:09 AM Thread Starter
Unclemoak
1981 CJ7
I've searched all the usual suspects - Rock Auto, Auto zone, Advanced Auto, Oriellys, Napa and am coming up short on finding the proper coolant temperature sending unit. Seems all the replacements that I come across have 3/8" NPT threads and the original has 5/8" NPT threads.
Anyone gone down this road before?
Unclemoak is offline
post #2 of 9 Old 09-21-2017, 08:34 AM
bob4703
1974 CJ5
Buy a 5/8" to 3/8" reducing bushing. Parts store should have them, as should Ace, HD, or Lowe's. Look in plumbing supplies.
Used to be parts stores were staffed with gear heads, but now they are computer oriented.
Paved roads are prime examples of government over spending!
bob4703 is offline
post #3 of 9 Old 09-21-2017, 09:22 AM
caseypotts
1980 CJ7
Temp
I've been in the same boat you are in for years. I bought the correct sender in the late 90's early 2000 from NAPA. Looking back I wish I would have bought the whole store. Since then I've never found it again. I did the reducer thing but it has never worked correctly since. I plan I getting a Speedhut Gauge next month, and hoping that this will solve all may issues...least those involving my gauges.
1980 CJ7 GM151 Bored out, Flat Top Pistons, Hedman Header, 2.5in Superlift springs, Extrem Shocks' 31 10.5 Mastercraft Courser MT tires on Allied MockLoc rims, Blazer heater upgrade.
Her Ride
2003 Liberty Renegade
caseypotts is offline
post #4 of 9 Old 09-21-2017, 09:32 AM Thread Starter
Unclemoak
1981 CJ7
I don't have a good reason, but I'd like to avoid using adapters. Call me crazy, but there has to be someone out there that makes the correct sending unit.
post #5 of 9 Old 09-21-2017, 10:22 AM
bob4703
1974 CJ5
It is an easy and inexpensive fix. I've used the same bushing since I upgraded my temperature gauge.
Try a dealership Chrysler and GM as it is a GM engine, but be prepared to pay. Then hope it will work with your gauge.
bob4703 is offline
post #6 of 9 Old 09-22-2017, 06:04 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Personally, I would run the bushing. This is a common fix for aftermarket intakes that carry the sender.
Otherwise, have you tried cross referencing a GM car of the same year?
something like this:
https://www.carjunky.com/coolant_tem...~oemparts.html
You can get a list of cross referenced vehicles from wiki and go to you FLAPS and just start pulling senders off the shelf.
bazinga
jeepdaddy2000 is offline
post #7 of 9 Old 10-09-2017, 02:03 PM
momo2
1980 CJ7
Same problem here. But i recently bought a Standard Motor TS 162 sender on ebay as there is some evidence that it can be crossreferenced to the original part number J 5751811. The sensor has the right npt thread and terminal but it's longer and the bottom end is more narrow. Compared the resistance to the values for the temperature gauge given in Factory service manual and the ts 162 seems to be a a bit higher. Values in the FSM are for the 258 however and there was a lot's of eyeballing on my side. Nevertheless i will give it a try.
momo2 is offline
post #8 of 9 Old 10-10-2017, 08:58 AM Thread Starter
Unclemoak
1981 CJ7
Please let us know if it ends up working.
post #9 of 9 Old 10-11-2017, 05:21 AM
momo2
1980 CJ7
Good news. Ts 162 works fine. Needle stayed between the c-mark and the green band most of the time. As the engine got a little hotter - around 85 to 90 degress celsius at the cylinder head - it slightly entered the band. Good luck with your project, i just finished mine.
momo2 is offline
