Sound and thermal insulation for floor in the CJ - JeepForum.com
post #1 of 9 Old 02-12-2016, 10:42 PM Thread Starter
cuban11182
I'm thinking about having the jeep dipped to remove all the paint and the previous owners DIY bed liner. I would prefer to not have any carpet, so I'm wondering what products are available to accommodate that idea. I saw Dynadeck, but haven't really found many reviews from any Jeep forums. I'd even be up for the idea of having the jeep painted, and the floor rhinolined the same color if there was something I could ad below the liner.
Thanks in advance.
cuban11182 is offline
post #2 of 9 Old 02-13-2016, 10:44 PM
holliewood61
holliewood61's Avatar
1981 CJ7
You may look into lizard skin for the under side of the tub. Its a ceramic based spray on coating that deadens sound and insulates from heat.
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is online now
post #3 of 9 Old 02-13-2016, 11:18 PM
berserk71
1977 CJ5
I used that on my fire wall. Can't say it helped much because it's just on the firewall. I plan on spraying more under the tub when I pull the trans. I've heard wheel wells are a major source of sound.
berserk71 is offline
post #4 of 9 Old 02-14-2016, 06:01 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
I used the rubberized 3M Professional Under-coating on the underside of my tub.
It helped to dampen road noise, some.
Matt
Matt1981CJ7 is offline
post #5 of 9 Old 02-14-2016, 08:36 PM
Chrisinchwk
1982 CJ7
I just roll the windows down. Drowns out everything. Oh wait I have no windows or top
I have heard undercoating of any sort helps. In my 2015 I had it done a week after purchase, huge sound difference
Chris
Chrisinchwk is offline
post #6 of 9 Old 02-15-2016, 03:35 AM
Jeepn-n-tx
I went by Mike Honcho...
Jeepn-n-tx's Avatar
1981 CJ7
"How do I reduce the road noise?" asks the guy with no doors or top. HAHAHAHAH!!! (j/k)
I'm about the start working on the tub for my Black Whale project. After the metal work is done, I plan to use POR15 on the underside, engine bay, & fender wells, & then like Matt, I plan to add the rubberized undercoating.
Matt - I can't remember ... did you do you own or have a shop spray it?
Jeepn-n-tx is offline
post #7 of 9 Old 02-16-2016, 06:12 AM
Matt1981CJ7
1981 CJ7
DIY.
Matt
post #8 of 9 Old 03-01-2016, 10:23 AM
mdkelley
1978 CJ7
check eastwood. they have some kind of spray on deadener or paint if I recall.
update:
found a link. Looks like the stuff that was already mentioned, and is quite pricey
http://search.eastwood.com/search?w=...ener&ts=custom
mdkelley is offline
post #9 of 9 Old 03-01-2016, 10:28 AM
mdkelley
1978 CJ7
do you have a hard top and doors, or soft top? If it is a soft top, there won't be much you can do to reduce road noise short of getting a hardtop/hard doors. My dad's YJ was a soft top and even with the factory carpet it was much louder than my CJ with no carpet but a hardtop/doors. You didn't mention what the top was so I assumed it was a hard top. If this is more for thermal barrier and less for sound, some of the ceramic paints available get good reviews for heat reflecting capabilities.
mdkelley is offline
