Sonic's 74 CJ5--build??? - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Sonic's 74 CJ5--build???
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 10-22-2010, 04:41 PM   #76
Jim1611
Jim1611's Avatar
Originally Posted by sonicr1 View Post
Thanks Jim, I have spent a little bit of time on the body and am just getting frustrated, so this will be a good time to check the measurements!!!!!
You're welcome Bill and please do check them, to ere is human and I am very human!
www.crabtreetool.com (Crabtree Shackle Hangers)
My build thread
http://www.jeepforum.com/forum/f8/ji...build-1093702/
Jim1611 is offline   Reply With Quote Quick reply to this message
Unread 10-22-2010, 05:08 PM   #77
SonicR1
Deadman, believe me, patient is something I'm not... determined, yes!!! I will not let this stupid thing beat me!!
So I started out today trying to build up the the layers of filler... only to get frustrated with it drying and solidifying too quickly.
I came in, responded to Jim's message and measured my JEep to find that our dashes are different widths, and I'm gonna have to go through Double D to get a dash... no biggy, and not much more expensive anyway.
I finally got a couple nice coats on and started sanding. I think I'm starting to understand why I was getting frustrated to begin with. I didn't have enough buildup to actually sand down to smooth things out, but I'm starting to get there...
A couple more coats and I'm there... unfortunately I'm done for the week.
[COLOR="Red"]... I guess I'm gonna have to fix that too…….[/COLOR]
[URL="http://www.jeepforum.com/forum/f9/sonics-05-tj-build-1168663/#post10985489"][COLOR="yellow"]The TJ[/COLOR][/URL]
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
[URL="http://www.jeepforum.com/forum/f8/sonics-74-cj5-build-1106795/"][COLOR="DarkOrange"]1974 CJ5 BUILD THREAD[/COLOR][/URL]
SonicR1 is offline   Reply With Quote Quick reply to this message
Unread 10-22-2010, 05:24 PM   #78
Coiz
1979 CJ7
When you finish mixing a batch of filler, take your spreader and apply a very thin coat pushing firmly on the surface. Make it so thin that you're basically trying to make the surface look wet, this helps ensure good adhesion. Then go back and build up a nice layer of the filler. Wait about 5 minutes and start checking the tackiness of the filler. You want to hit it with the 60 grit block sander right in between the point of it being tacky and rock hard. It will gum up your sand paper like crazy but your only trying to quickly get the main form and knock down the high spots. Then give it another few minutes to cure and get a bit harder before you finish sanding.
If you can time it just right you can really knock down the sanding time. If your waiting until it's hard before you ever touch it with the sand paper, you're easily tripling the amount of sanding time required.
Mike
My build thread
Coiz is offline   Reply With Quote Quick reply to this message
Unread 10-22-2010, 05:27 PM   #79
SonicR1
Yeah, I started out waiting till it was hard, but my boss was telling me to knock it down first, like you said... that helped a lot!!! But it is still an art... I'm better with math!!!!
Thanks for the help!!!!!
Unread 10-22-2010, 05:29 PM   #80
Coiz
1979 CJ7
Well it is already looking better and coming along nicely. Keep up the good work.
Mike
My build thread
Unread 10-22-2010, 08:29 PM   #81
Skerr
Skerr's Avatar
Thanks for the pics of the materials. Now I feel like I'm on the same page!
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 10-22-2010, 09:48 PM   #82
Jim1611
Jim1611's Avatar
Bill you're almost there man!! That is looking great.
My build thread
Unread 10-22-2010, 10:17 PM   #83
243
1978 FSJ Cherokee
It is looking a lot better!
1978 Cherokee, 360/T400/QT...5.3/4L60E/NP241C in the works...
243 is offline   Reply With Quote Quick reply to this message
Unread 10-22-2010, 11:04 PM   #84
83vert
1982 CJ7
I agree nice work
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline   Reply With Quote Quick reply to this message
Unread 10-22-2010, 11:48 PM   #85
cjdogtoy
1976 CJ5
keep it up you've got the hang of it.
cjdogtoy is offline   Reply With Quote Quick reply to this message
Unread 10-28-2010, 04:30 PM   #86
SonicR1
So, I started investigating the little volcano that I didn't notice while I was doing the cutting and welding... nice spot of rusted support channel on the inside... oh well, it is too late for anything more than a cosmetic fix.I cut out a square and welded a piece in... the inside will probably rust through again in a couple years, but I'm soooo done!!!
I started the day with the idea of just removing all the filler I had so I could start over...
It actually turned out better than I expected, I think I will be done with most of this side tomorrow...
I am hoping to order some comp cut tube fender flairs from jeeptubes.com hopefully in the next week, but this body work is just killing me!!!
I have been thinking about taring into the TC and the Tranny, but I hate getting into something else while this is so unfinished!!!!
GO GIANTS!!!!!!!
Unread 10-28-2010, 04:39 PM   #87
Jim1611
Jim1611's Avatar
Hey Bill it's good to see you back at work. The side is shaping up very well. Why stop and start on something else though, you look like you're really gettting the hang of it and before you know it you'll have this part done.
My build thread
Unread 10-28-2010, 04:46 PM   #88
SonicR1
Sometimes I just start pressing and things start screwing up, as I said before, I am not patient, so this slow build is killing me!!! My plan was to just get this thing running and flog the snot out of it, but I also wanted to make sure it wasn't going to fall apart if my wife decided to drive it to work...
I WANT TO BE DONE!!!
Unread 10-28-2010, 08:24 PM   #89
Matt_G
1979 CJ5
not that this is wrong, but if you want to cut down on sand paper they make a tool called a body file for this exact purpose. i think i got mine for less then $5 and it has certainly saved me a ton
"This isn't mud, it's a special Jeep Wax"
Matt_G is offline   Reply With Quote Quick reply to this message
Unread 10-29-2010, 01:40 PM   #90
SonicR1
Unfortunately this has been a short weekend for me and I didn't get as much done as I wanted!!! I feel like I'm posting the same pic over and over... and it feels like I'm at the same spot I was at when I posted the first pic!!! Uuuuuggggghhhhhhh!!!
Well here it is, I think I'm done... I will get some high yield next week and smooth it out.
The big ripple under the door is going to be covered with a rocker guard, so I really don't care about it anymore!!!
