Someone sell me some headlights.... - JeepForum.com
post #1 of 21 Old 01-07-2014, 05:36 PM Thread Starter
UBERK
1976 CJ7
Since I have the grill off to pull the motor Im going to take the time to wire in some relays IE: headlight relay mod, as well as put my aux lights on a relay.
For lights I have them narrowed down to:
Cibie's for $80ea
Hella Vision Plus for $100 pair
KC Performance for $100 pair
Are the Cibies that superior of a light to cost an extra $60...?
UBERK is offline
post #2 of 21 Old 01-07-2014, 05:53 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Yes, they are.
CJ7-Tim is offline
post #3 of 21 Old 01-15-2014, 06:56 PM
Fletchlives85CJ
It sounds like you are lookin for off road lights. If you want to greatly improve your factory head lights, gain a nice clean factory plug to run relays driven by high/low beams, and not spend a fortune, I can say from first hand experience that the "heavy duty headlight harness" (~$30) from LMC Truck, with Sylvania Silverstar replacement lamps(not sure, I think ~$75) is absolutely awesome, ridiculously simple to perform, and will make wiring your off road lights even easier.
Fletchlives85CJ is offline
post #4 of 21 Old 01-15-2014, 07:18 PM Thread Starter
UBERK
1976 CJ7
No. Just looking to improve my factory Hi/Lows.... I am doing the relay mod, but also want to start with a quality light.
So....all things equal, meaning Cibies and Hellas...on relays...are the Cibies worth the extra $$...and why.
UBERK is offline
post #5 of 21 Old 01-15-2014, 07:23 PM
walkerhoundvm
1981 CJ8
I went with simple autopals off of eBay for $60 shipped and couldn't be happier. In my opinion only, if you're looking to spend extra money, just go with the hellas and I'll bet you'll be happy as a clam.
walkerhoundvm is offline
post #6 of 21 Old 01-15-2014, 07:37 PM
WSS
WSS's Avatar
1972 CJ5
Do you guys have links for these lights? Which cibie will fit our old CJs? And wich autopals work too?
WSS is offline
post #7 of 21 Old 01-15-2014, 07:48 PM
walkerhoundvm
1981 CJ8
I can't remember the specific autopals, they were standard 7" dot-approved lights iirc. Even came with a pair of lamps.
post #8 of 21 Old 01-15-2014, 07:52 PM Thread Starter
UBERK
1976 CJ7
IF, I were to decide on Cibies, Id get them here:
http://www.danielsternlighting.com/p.../products.html
Otherwise Id just use Quadratec for a PN and search Amazon for the best deal.
UBERK is offline
post #9 of 21 Old 01-15-2014, 07:56 PM
JeffreyCharles
1976 CJ5
I've also had good luck with Daniel Stern. Bought relays, Cibie reflectors and Osram bulbs and love how much brighter things are. I wrote it up here a few years ago and have since purchased replacement bulbs from Mr Stern (only needed one, but replaced the pair and kept the one older good bulb as a spare).
http://jeep.smallcraft.net/lighting_upgrade/
Jeffrey Charles
JeffreyCharles is offline
post #10 of 21 Old 01-15-2014, 08:19 PM Thread Starter
UBERK
1976 CJ7
Originally Posted by JeffreyCharles View Post
Nice page you have there....
UBERK is offline
post #11 of 21 Old 01-15-2014, 11:22 PM
NateC
I bought the KC headlights and have been very happy with them.
NateC is offline
post #12 of 21 Old 01-16-2014, 03:42 AM
chucker2
1981 CJ7
chucker2 is offline
post #13 of 21 Old 01-16-2014, 06:11 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Hey Jeffrey,
I think the headlight relay upgrade is going to be my next project.
Did the Stern relay kit come with the necessary provisions to re-wire the side markers?
Also, you mentioned upgrading the bulbs in your signal indicators, perimeter running lights, brake and back-up lights. Do you happen to have part#s or links to those items?
Thanks,
Matt
Matt1981CJ7 is offline
post #14 of 21 Old 01-16-2014, 06:49 AM
GlennLever
GlennLever's Avatar
Here is a thread on relays, some good information some not so good
http://www.jeepforum.com/forum/f8/cj...grade-1411011/
If you are just wanting to get better stock headlights you might try good grounds and power (direct from the battery) the difference is amazing.
It is easiest to do the wiring with the grill out, but the headlight upgrade can be done with the grill in.
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
post #15 of 21 Old 01-16-2014, 08:04 AM
turbogus
1978 CJ5
Yeppirs, inkeeping with the JeepHammer idiom, proper grounding back to the battery makes for no bottlenecks in current flow so full battery power is uninhibited. How I did mine was by using a ground bus bar that attaches directly to the negative terminal of the battery, this way I have all the grounding contacts solid, centralized, and easily reached for future projects.
I've been using Hella Vision plus on my panel van 'Easy Bake' my bike Kaw Z1R turbo 'Go Fast' and my CJ5 'Black Betty' for years now and the manner in which Hella flutes the lens makes for superior lighting from what I've seen, I use Flösser 145/100's which seem to outlast all other H4's available locally.
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
