someone put 1 piece axle shafts in before and i didnt notice it at first - JeepForum.com
post #1 of 12 Old 10-20-2013, 05:55 PM Thread Starter
seabass1858
1983 CJ7
was doing my rear brakes because of a leaky wheel cylinder and i was tired of filling one of my resivoirs of my master cylinder and found that i have 1 piece axle shafts of unknown make.
seabass1858 is offline
post #2 of 12 Old 10-20-2013, 06:29 PM
BlkCJ7Laredo
BlkCJ7Laredo's Avatar
And your Jeep was sitting for years correct? Who else was in the game for one-piece back then besides Moser? I know my Mosers that have been in there since the mid '90s have ME embossed on the shafts
'85 CJ-7 Laredo currently under construction.
BlkCJ7Laredo is offline
post #3 of 12 Old 10-20-2013, 07:07 PM Thread Starter
seabass1858
1983 CJ7
the original license plate expired nov of 1997
post #4 of 12 Old 10-20-2013, 09:02 PM
fourbtgait
1930 MK Patriot
Looks like a set I just replaced in my rear end. Never could figure out who had made them or when originally instaaled, but the inner seal was leaking which had washed out the bearings. Plus the PO install had banged up the axle shaft installing the bearing, so I went with a new axle kit.
fourbtgait is offline
post #5 of 12 Old 10-20-2013, 09:16 PM Thread Starter
seabass1858
1983 CJ7
axle seal looks fine but i ended up with a mess running around with leaking wheel cylinder and i just kept putting brake fluid in it until tonight i had enough lol.
post #6 of 12 Old 10-21-2013, 06:13 AM
shadoow
they look like the ones i have, but am not sure who made mine. I looked all over the exposed areas for some kind of identifying mark but couldn't find any. Bearings and seals are good so far so guess i'll deal with it when the time comes....
If you figure it out, please post
shadoow is online now
post #7 of 12 Old 10-21-2013, 06:51 AM
Blakescj7
mine kinda look like that, i have currie shafts
Blakescj7 is offline
post #8 of 12 Old 10-21-2013, 07:02 AM
shadoow
are there any markings on them you can see without dis-assembly?
post #9 of 12 Old 10-21-2013, 09:50 AM
John Strenk
John Strenk's Avatar
1976 CJ5
or I think they might be Superior.
I still have a new set for a narrow track laying in the barn.
John Strenk is offline
post #10 of 12 Old 10-21-2013, 12:28 PM Thread Starter
seabass1858
1983 CJ7
I guess it beats an original 2 piece shaft.
post #11 of 12 Old 10-21-2013, 04:22 PM
yahwhy
1982 CJ7
x2 on Think they might be superiors, I forget the numbers, but its something like three #s and either s or L/short/long
stamped on the big face wheel stud end.
yahwhy is offline
post #12 of 12 Old 10-21-2013, 05:14 PM Thread Starter
seabass1858
1983 CJ7
found the superior marking on the otherside. Now to open the differential and hope for 4.10s and a truetrac
