Someone Please Post A Pic Of Your CJ Tailgate....
#1 | |
I'm looking to gather up parts to install a CJ Tailgate in my CJ5 which currently doesn't have a tailgate. Could you guys/gals help me with the following pics:
- Shot from inside the tub showing back of the tailgate - Latch mounting points - Hinges - Tailgate open/closed position - Strap and Strap mounts - And anything else I'm forgetting........... Need the pics ASAP folks as I'm trying to order a tailgate today or try to find one on craigslist (not very lucky so far). ![]()
Jason "MJ" - 79 CJ-5 | SOA/HI-STEER | 304/T18A/D20 w/3:1 TeraLow | Holley Avenger Carb | Edelbrock Performer Intake Manifold | DUI Distributor | K&N Filter | Centerforce 2 Clutch | Waggy D44's | 4.11's | ARB's | Corvette Master Cylinder | HAD Shafts | 35 Toyo MT's| If you own a Jeep and serve in or are a Veteran of the U.S. Military come visit us at: MilitaryJeepers.com
#2 |
Bicentennial Nickel
Read through this and see if you still have questions...
certifiablejeep.com - New Tailgate Installation cb |
#3 | |
#4 |
bump to top
#5 |
Bicentennial Nickel
go forward and backward from this page... it was a Wrangler tub that got a CJ tailgate conversion...
certifiablejeep.com - Project "Free Jeep" a.k.a Project "FJ" - part #30 Putting one on a 5 could work, you will need to get all the mounting brackets, the hinges, the cables... Also, check the size of the openting from 5 to 7 to make sure it fits in there nicely. Craig |
#6 | |
Thanks again for another link......appreciate it. As for the tailgate, I'm starting with a blank wall as the Jeep never had a tailgate so it should be fairly easy (all things considered) as long as the first cut is correct ![]() I just ordered all the parts yesterday from 4wd so we'll see how it turns out. Still wishing there was others (besides you) that have some pics.......thanks again though. ![]()
#7 |
Bicentennial Nickel
the only other set of pictures is on the last Jeep I did... I don't know if you are looking for CJ5's with CJ7 tailgate pictures, but for the most part, I have never seen pictures of that, so I am not sure how many are out there.
certifiablejeep.com - Project "Curtis Jeep" - part #3 cb |
#8 |
Here are a few pictures for you hope these help a little, the yellow one is not mine
#9 |
Is the tailgate supposed to hang that low? I figured it would be horizontal to the ground? Are the ropes/wires strong enough to support a person's weight sitting on them or standing on them.
#10 |
Muddin Maniac
Normally they are horizontal. Yes you can sit on them, my 14 yr old is 6 ft 2 and weighs around 280 and it holds hin fine.
United States of America
Born: July 4, 1776 Died: Nov 4, 2008 SUICIDE |
#11 |
SlikRic, maybe that youngster will buy you a new jeep when he signs that NFL contract
#12 |
They should hang horizontal, I think the wires are to long on that jeep, you can sit on them just fine.
#13 | |
Bicentennial Nickel
cb |
#14 |
just a jeeper
It looks to me that the hinges on the yellow jeep might be upside down, the open tailgate is way to close to the tub. My CJ7 tailgate holds my 205# just fine, And lowers level with the bed. The hinges on the gun metal jeep are the correct orientation.
1980 cj5 trail jeep 2-1984 cj7's (they were cheep) and run good, ones a winter dd the other in a pile of parts 1983 cj7 purdy dd in the summer 1979 cj7 project th400/quadratrac 2011 Grand Cherokee Laredo 4x4, Mrs. LUCDOG's dd 94 YJ for the wifey to scoot around in. |
#15 |
You are correct they are upside down. To put a 7 tailgate on a 5 is a little bit of work. first off the gate on the 7 is taller than the tub of the 5
Jeep :: 100_3881.jpg picture by Go3Win8 - Photobucket you'll need to trim and fix the top Jeep :: 100_3891.jpg picture by Go3Win8 - Photobucket fab your stops and catches 100_3884.jpg picture by Go3Win8 - Photobucket Jeep :: 100_3903.jpg picture by Go3Win8 - Photobucket Jeep :: 100_3904.jpg picture by Go3Win8 - Photobucket Jeep :: 100_3907-1.jpg picture by Go3Win8 - Photobucket it's fun. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
