Some random blinker problems... - JeepForum.com
post #1 of 6 Old 05-18-2010, 10:23 PM Thread Starter
CJ8Hokie
1983 CJ8
1983 CJ-8 with a Painless Harness and LED tail lights
With the headlights OFF my all my blinkers work just fine, although the front passenger blinker is quite a bit dimmer the front driver blinker.
With the headlights ON the right blinkers only blink every few seconds.
When using the hazards all the lights (except the front passenger blinker under the headlight) blink at the appropriate rate.
I'm not sure how long it has been like this, perhaps since when I put the Painless harness in a few years ago. When I installed the painless kit it appears that I used the prior harness's flasher to compensate for the LED tail lights. I checked what grounds I could, and everything seems to be OK. The headlights are all the right brightness, etc.
Any thoughts? Thanks in advance!
1983 Jeep CJ-8 - Clifford Performance 258/4.0 with MPFI
CJ8Hokie is offline
post #2 of 6 Old 05-18-2010, 10:26 PM
Trapshooter
Check your grounds once more. When one light is brighter than the light on the opposite side; you have a faulty ground nine times out of ten.
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 6 Old 05-18-2010, 10:31 PM Thread Starter
CJ8Hokie
1983 CJ8
OK, I'll check that out tomorrow. The blinker body acts as the ground, and it seems to be making good contact with the grill, but I'll see if I can't get it even better.
Come to think of it: I did take the blinker out completely, and even when grounding it perfectly to a bolt on the bumper it still didn't blink correctly, although it did shine brighter as a running light.
CJ8Hokie is offline
post #4 of 6 Old 05-19-2010, 04:49 AM
hybridcj
check your turn signal switch.
hybridcj is offline
post #5 of 6 Old 05-19-2010, 04:56 AM
GP_Pete
GP_Pete's Avatar
Low blinker fluid.
CJ8Hokie - 'Hokie' as in VT?? Glad to see the Hokie Nation is strong on JF! (class of '98)
GP_Pete is offline
post #6 of 6 Old 05-19-2010, 07:09 AM Thread Starter
CJ8Hokie
1983 CJ8
HybridCJ - The switch has been giving me some trouble, most notably it no longer auto-cancels on left turns.
Pete - I flushed the fluid recently, but maybe I'll switch to synthetic. That's right on being a Hokie! I was class of 2003. I was supposed to be 2002... but I stuck around for the victory lap..
CJ8Hokie is offline
blinker problems flyin8s234 Jeep CJ Forum 8 03-03-2010 02:55 PM
Radio/Blinker/Fuel/Temp Gauge Problems hieber22 Jeep CJ Forum 4 09-24-2009 04:06 PM
Blinker Worries/Idle Problems...... sweetguardian00 Jeep CJ Forum 1 05-04-2008 09:43 AM
Slooooooow blinker? shoboat90 Jeep CJ Forum 4 11-08-2005 03:20 AM
Blinker Problems CJ-7MAN Jeep CJ Forum 1 03-20-2004 05:26 AM
