Some advise - JeepForum.com
post #1 of 3 Old 06-27-2005, 09:21 PM Thread Starter
CNs CJ
Some advise
I am looking at a 79 CJ 7 with a 304 in it with a 3 speed. I dont thin the engine is origanal? They said it came out of a Javalin? where these the same motors? What should I look for on the frame and axles? I plan on tearing it all down and putting about 6 to 8 grand in it. The guy wants 800 bucks. I know I am only buying the drivetrain, I just dont know what to look for. is this engine not being factory really bad? Thanks
CNs CJ is offline
post #2 of 3 Old 06-27-2005, 09:41 PM
schmoken
schmoken's Avatar
I wouldn't worry about the engine not being original. Jeeps get all kinds of transplanted powerplants.
Check the frame around the steering box for cracks and around the spring hangers too.
The rear crossmember is a common rot spot, but those aren't too bad to replace.
Broken body mounts.
Unless its a total rusted out pos, you can't complain about $800 for a V8 cj.
A bunch more advise coming I'm sure.
schmoken is offline
post #3 of 3 Old 06-28-2005, 12:48 AM
SQF1
1976 CJ5
Javalins had the same motor. I would look close at the frame. Everything else can be replaced fairly cheaply and easily. In addition to the above mentioned areas pay specific attention to the forward rear hangers where the frame dips and rises again. That is where the factory drain holes are. They get plugged and rot from the inside out. Mine was almost perfect on the outside of the framerail but nearly nonexistent on the inside. The hanger itself masked the ammount of rot.
SQF1 is offline
Need Power Advise echolk Jeep CJ Forum 6 01-31-2008 04:52 PM
wanting to get a CJ, but need some advise. rusreus2 Jeep CJ Forum 9 11-07-2007 09:49 PM
Need advise....... MuddyMules Jeep CJ Forum 6 09-03-2006 09:19 AM
84 Cj for $12,000 need advise bkeast17 Jeep CJ Forum 6 10-08-2005 02:39 PM
Looking for Advise cnixon Jeep CJ Forum 9 09-08-2005 07:04 AM
