Solenoid wiring question. Help! - JeepForum.com
post #1 of 4 Old 10-09-2002, 09:29 AM Thread Starter
Bob K
Bob K's Avatar
Hi guys. I just jumped over here from the YJ board. I think starting system is more like a CJ since my YJ is a 1987, built by AMC. Here goes...I got confused about the wiring on my solenoid. I have a Black/white wire with a L-shaped connecor. I have two small posts sticking out forward at 45 degree angles from my solenoid. On your jeep, if you have this set up, does the Blk/wht wire connect on the driver's or passenger's side post. I really need to know soon.
Thanks,
Bob K
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #2 of 4 Old 10-09-2002, 05:19 PM
CSP
Honestly I can't remember and my CJ isn't home to look at. I do know that if you get it wrong you won't hurt anything and the solenoid won't work. Try it on one plug and if it works you have your answer. If it doesn't work you still have your answer. I've hooked mine up to the wrong post before and that was my experience.
CSP is offline
post #3 of 4 Old 10-09-2002, 05:28 PM Thread Starter
Bob K
Bob K's Avatar
Hmmmmm. Right now mine works both ways, but cuts out frequently when plugged on the left post, sometimes cuts out on the right (drivers side) post. I'm hoping to get the solenoid wired right then track down the actual problem.
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Bob K is offline
post #4 of 4 Old 10-09-2002, 06:30 PM
werewolf7111
little advice here
a solenoid is just that a magnetic switch that allows either voltage or current to activate another device.
in the case of a 12VDC solenoid, EITHER terminal will engage the starter and crank the engine
( ONCE IN THE RUN MODE, IT DOESNT MATTER)
joe MSME, PE.
werewolf7111 is offline
Solenoid Wiring 85 CJ7 4.2 macg1777 Jeep CJ Forum 4 01-24-2010 09:24 AM
Starter Solenoid Wiring Question texashighridin Jeep CJ Forum 7 01-15-2008 02:37 PM
solenoid wiring 86 c77 takisanjeep Jeep CJ Forum 1 04-17-2007 11:00 AM
starter solenoid wiring help T-$$ Jeep CJ Forum 4 09-02-2005 11:07 AM
Need help with Starter Solenoid wiring Marc CJ7 Jeep CJ Forum 17 04-19-2004 05:22 PM
