Solder Splice Connectors? - JeepForum.com
post #1 of 16 Old 02-07-2010, 08:04 AM Thread Starter
boomvader
I am in the middle of changing out my TBI and installing a new MSD Ignition. I also removed the old computer and the associated harness. What a difference removing all those old wires makes!
I am new to heat shrinking and soldering and I would like to find a good solution for connecting my wires properly. Has anyone used this product?
Fusion™Solder Heat Shrink Splice - Solder Splice Connector
-boom
Boom's CJ-7 Project (Completed in 2011)
boomvader is offline
post #2 of 16 Old 02-07-2010, 08:16 AM
frank c
1981 CJ5
For the cost of the smaller set 34.95 you could BUY and OWN an inexpensive soldering iron,crimping plier, flux, more connectors than come with the set and youll ever need, a couple rolls of electrical tape, heat shrink tubing and have money left over.
As far as the quality of the connector set you referenced in your link I have no idea. And according to the directions given you better be experienced with applying heat and connections besides the fact that they say" you must seperate the individual wires to make to proper connection" what a PITA.
Soldering and connecting wires is a simple, quick task an can be learned very quickly an easily by anyone.
frank c is offline
post #3 of 16 Old 02-07-2010, 08:18 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Freightliner factory warranty requires using something like that. Use the uninsulated crimp connectors to join the wires, then put those over the splice and then they want you to use another heat shrink over that (overkill?). The uninsulated crimp connector has a small hole in the side, allowing the solder to melt into the wires inside. Also recommended to not touch the bare wires after stripping them, so the oils/dirt on your hands do not cause contamination of the splice.
I'd definitely use those that you found, unless you are going to use a solder iron and solder then heatshrink. Either way, as long as the solder holds the splice secure, it is a better splice than plain crimp connectors like many seem to like to use...
Rick
Cutlass327 is offline
post #4 of 16 Old 02-07-2010, 09:57 AM
Mike Romain
I don't really like those. My little butane torch (something like the one they show) always wants to overheat the plastic causing it to split so I gave up on them quickly.
I like to solder the connections put together like shown or use a plain crimp connector, then solder that and then slide the waterproof heatshrink over that joint. They make a waterproof heatshrink with glue in it for automotive use vs the plain stuff for electronic use. If all I have is the electronic heatshrink, then I use dielectric grease inside it before shrinking.
Mike
Mike Romain is offline
post #5 of 16 Old 02-07-2010, 11:10 AM
Gemelos
Gemelos's Avatar
1976 CJ7
I have those to and don't like them.
I prefer soldering .. Old wire is sometimes corroded and the tin does not stick so good then. when you use these thing you'r not sure you have a solid connection.
When soldering and the tin does not stick you can clean up the wire with sandpaper, solder and inspect the connection again.
Grts from Belgium
Gemelos is offline
post #6 of 16 Old 02-07-2010, 12:44 PM
CJ Chet
You need a heat gun for shrink tubing, NEVER a flame.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #7 of 16 Old 02-07-2010, 12:47 PM
alex211
1995 XJ Cherokee
I use a lighter for heat shrink tubing, it works fine.
Care to elaborate?
95 xj bone stock for now
alex211 is offline
post #8 of 16 Old 02-07-2010, 01:02 PM
Coiz
1979 CJ7
Originally Posted by Mike Romain View Post
They make a waterproof heatshrink with glue in it for automotive use.
That's the good stuff.
Mike
Coiz is offline
post #9 of 16 Old 02-07-2010, 01:42 PM
popascj7
1976 CJ7
where can you find the good heat shrink?
popascj7 is offline
post #10 of 16 Old 02-07-2010, 01:57 PM
Coiz
1979 CJ7
Quick google search found this. Search for dual wall or weatherproof heat shrink.
Mike
Coiz is offline
post #11 of 16 Old 02-07-2010, 02:16 PM
popascj7
1976 CJ7
Thanks Coiz
All the tubing I've found locally is just the tubing, quess I'll be ordering some.
popascj7 is offline
post #12 of 16 Old 02-07-2010, 08:27 PM
Bubba Ray
Gemelos, have you heard of Picanol?
Bubba Ray is offline
post #13 of 16 Old 02-07-2010, 09:30 PM
duffer
1955 CJ3B
digikey.com about any kind of heat shrink made.
duffer is offline
post #14 of 16 Old 02-07-2010, 11:04 PM
Gemelos
Gemelos's Avatar
1976 CJ7
Yes, it's a company in Ieper that makes weaving machines...
Verry HiTech stuff, to bad there bussiness is not running so well.
Competition with China is killing them I heard on the news...
Gemelos is offline
post #15 of 16 Old 02-08-2010, 01:27 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Care to elaborate?
Heatshrink, not Flameshrink.. lol
Rick
Frame Splice Advice texasdave Jeep CJ Forum 4 10-27-2009 06:07 PM
where to splice in to headlights for off road lights? kc8emr Jeep CJ Forum 6 04-08-2009 03:15 AM
Anyone try solder pellets? davemci Jeep CJ Forum 15 04-08-2009 12:57 AM
Lead Free Solder stephens_cj5 Jeep CJ Forum 3 06-18-2008 05:38 PM
Please teach me how to solder... RLBJeep Jeep CJ Forum 15 03-20-2007 07:42 PM
