Soft Top Installation - JeepForum.com
post #1 of 3 Old 04-10-2009, 04:29 PM Thread Starter
McGough
I just bought an 85 CJ7 and it has the original whitco soft top with all the hardware. I am going to try to install the soft top, but don't have installation instructions. does anyone know where I can ge instructions.
thanks Al
McGough is offline
post #2 of 3 Old 04-10-2009, 05:09 PM
Mike Romain
I just moved to a small temporary place and most stuff is in storage, but I have the Whitco booklet and the softop on mine.
I should be able to walk you through most of it it, can't get at the booklet....
On the top rail of the box, about a foot behind the door opening, there should be two holes drilled about 3" apart. These are for the hoop base. The base goes in with the taller side forward and the hoop with the extension capabilities goes on the bottom.
The door frame is two rods. The top rod has the 'top hat' shape socket for the upright that goes to the outside of the bar. The upright's bar goes to the outside of the 3 claw foot with the hook toe on the foot in the first hole on the tub's rail and the two on the back side straddling the rail.
These two rods fit into sewn channels on the softtop door frame. The top rod comes out a slot about 4" from the front.
There is a front top windshield channel that the front lip of the softtop has to tuck into as the first step. Then the door frame rods and fit it into the first hoop, there are snaps and strap at that corner spot to hold the top to the hoop. Then the back hoop has two strap and snaps to grab it to the top. Then you start at a door corner on the snaps and work back pulling down hard usually.
I think that is it.
Now if you need all the snap measurements and those things, I can't really get exact without the paperwork, sorry. The rail placement I can help with.
The top edge of the windshield needs to be 75 1/8" to the back top edge of the tub measured in 20" from each edge. Found that from another of my posts...
Mike
Mike Romain is offline
post #3 of 3 Old 04-10-2009, 06:19 PM Thread Starter
McGough
soft top install
snaps are already installed.
McGough is offline
Need OEM Whitco soft top installation instructions for a 1985 CJ7 JeepScrambler Jeep CJ Forum 1 11-07-2009 11:41 AM
76 CJ5 Soft Top installation Mike2411 Jeep CJ Forum 10 10-18-2009 12:09 AM
CJ soft top installation shaunstickler Jeep CJ Forum 2 08-11-2004 10:18 AM
looking for full soft top for CJ-8 & doors hard or soft tarponbooter Jeep CJ Forum 0 02-21-2002 01:28 PM
76 cj7 soft top installation jepthng1 Jeep CJ Forum 0 02-16-2002 10:21 AM
