SOA or Suspension Lift? - JeepForum.com
post #1 of 11 Old 08-25-2009, 10:36 PM Thread Starter
breakthru
Hello Peeps,
I'm trying to get 35x14.50's to fit comfortably under my 85 CJ. Do you recommend a good SOA job or 4 inch suspension lift with a combination of a body lift and/or taller shackles? Any advice is appreciated. Also, with either route, I would like to swap out to YJ springs... should I swap front and back or just front if I do the lift?
C
1985 CJ-7 258ci with a T5 tranny, Dana 300 t-case with Tera Low 4:1, 4" sagging Suspension lift, Warn floating axles, all around disc brakes, DUI Distributor, stainless brake lines, flexalite dual electric fan, weber carb, and 33 AT. Future mods include going to 35's under a Rubicon Express lift with full body replacement, interior restore and train horn... with time, money, and weather permitting.
breakthru is offline
post #2 of 11 Old 08-25-2009, 10:54 PM
jeepmaster03
1982 CJ7
I'm a SOA fan. That's just me. If doing the YJ spring conversion go ahead and do front and rear. That's My .02$
jeepmaster03 is offline
post #3 of 11 Old 08-25-2009, 11:22 PM
titomars
1981 CJ7
i am also a SOA fan i have 33's under my CJ7 with a SOA and no body lift. and they fit very comfortably.
titomars is offline
post #4 of 11 Old 08-25-2009, 11:47 PM
jeepmaster03
1982 CJ7
Hey breakthru cleam out your mail box. I tried to PM you but its full.
post #5 of 11 Old 08-26-2009, 08:06 PM Thread Starter
breakthru
jeepmaster... pm me if need be now. What's up?
post #6 of 11 Old 08-26-2009, 08:16 PM Thread Starter
breakthru
This may be a silly question, but if I do an SOA lift... and it adds 5" of lift, is that with stock springs? then if I got 2.5" suspension lift springs for the SOA, would that total 7.5" of lift?... is this how an SOA works?
post #7 of 11 Old 08-26-2009, 08:31 PM
dhubing
Yessir. Go SOA with the YJ springs, but stock height.
dhubing is offline
post #8 of 11 Old 08-26-2009, 08:57 PM
jeepmaster03
1982 CJ7
yup. 4.5" w/ SOA plus 2.5" lift springs = 7" lift. Now you can stuff 36" meats with no rubbing and maybe get 38's in there with some rubbing.
post #9 of 11 Old 08-27-2009, 07:19 AM
Happy Joe
IMO 7" is unsafe on the street. Even 5" with flexy springs is sometimes iffy depending on the driver (been doing/driving SOA for more than 20 years).
If its a street jeep stick with smaller tires, a standard suspension lift and better handling.
If its for off road use go with SOA and do a TJ or Scrambler fender flair mod to get the additional clearance needed for 33s to 35s (yes; I have trashed sheet metal (excessive rubbing) with 33s when flexed off road with SOA and no flair mod).
Your stock front axle and gearing are undersized for 35s in any case.
If you need to ask the question; you need to stick with a standard suspension lift and avoid SOA, IMO.
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline
post #10 of 11 Old 08-27-2009, 08:30 AM
CSP
SOA vs. a suspension lift depends on who's doing the work, how much experience they have, and what your budget is.
Spring over done correctly isn't cheap (especially if you're paying someone else) nor is it easy to do.
CSP is offline
post #11 of 11 Old 09-03-2009, 08:00 PM Thread Starter
breakthru
I'd have somebody experienced do it... I was considering the Rocky Road Outfitter's one... it seems to have some of the best components I've seen, especially the perches, but I'd definitely want to weld it.
Suspension Lift Help Jbrizzle Jeep CJ Forum 4 01-19-2009 07:20 AM
suspension lift 78GoldenEagle Jeep CJ Forum 13 05-08-2008 02:31 PM
Would someone please explain the difference between a suspension lift and a body lift Giff Jeep CJ Forum 5 09-20-2007 03:49 AM
Body lift vs. Suspension Lift jmreagan Jeep CJ Forum 4 02-10-2006 02:49 PM
CJ7 suspension lift guachinango Jeep CJ Forum 5 02-03-2005 03:12 PM
