Soa lift - JeepForum.com
post #1 of 49 Old 12-24-2013, 03:04 PM Thread Starter
77blackcj5
1977 CJ5
Soa lift
Ok so my cj5 has like a 3 inch boy lift that's pretty ugly. Seeing the entire frame under the jeep isn't very good looking. I am on a budget and was wondering, what are my options? I was thinking, get rid of the body lift all together, and doing a soa lift to make up for the loss of lift from
taking away the body lift. would this be driveable on the road?taking away
77blackcj5 is offline
post #2 of 49 Old 12-24-2013, 03:10 PM
CSP
A budget and spring over done correctly are mutually exclusive of each other.
CSP is online now
post #3 of 49 Old 12-24-2013, 03:23 PM Thread Starter
77blackcj5
1977 CJ5
What do you mean?
post #4 of 49 Old 12-24-2013, 03:34 PM
Spieg8
1984 CJ8
SOA even with stock springs will sit higher than the 3" body lift you are removing. If it where me, I'd stick to a SUA lift unless you're going for more than 5" of lift.
Spieg8 is online now
post #5 of 49 Old 12-24-2013, 03:36 PM
CSP
It can't be done on correctly the cheap.
At a minimum you need longer driveshafts, longer brakelines and shocks, some way to combat spring wrap in the rear axle. Steering corrections are necessary to avoid bump steer and a dropped pitman arm isn't the right way to deal with it.
On a narrow track CJ5 you should also go wider as you go taller (wider axles). A spring over with stock springs is at a minimum 5" of lift over stock.
This isn't something a beginner takes on either. There's a lot more to it than welding spring perches on the other side of the axle tube.
CSP is online now
post #6 of 49 Old 12-24-2013, 03:43 PM Thread Starter
77blackcj5
1977 CJ5
Really? Ouch
post #7 of 49 Old 12-24-2013, 05:45 PM
jp360cj
1977 CJ7
I'm in my soa about a grand, mostly for a new flat top knuckle and high steer stuff and new front drive shaft. still have to build another anti wrap bar (broke the 1st one), redo shock mounts and buy longer shocks. And would like to build DOM steering rods.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #8 of 49 Old 12-24-2013, 05:49 PM Thread Starter
77blackcj5
1977 CJ5
Gosh. Had no idea how difficult it was. Thanks guys
post #9 of 49 Old 12-25-2013, 01:33 PM
L78THUMPER
2007 MK Compass
I have no problems with mine
L78THUMPER is offline
post #10 of 49 Old 12-25-2013, 02:36 PM
jp360cj
1977 CJ7
Originally Posted by L78THUMPER View Post
i have no problems with mine
What size tires/springs are you running?
jp360cj is offline
post #11 of 49 Old 12-25-2013, 04:41 PM
L78THUMPER
2007 MK Compass
35's and stock springs
post #12 of 49 Old 12-25-2013, 04:54 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Also, the amount of fabrication/mechanical experience/ability will affect the cost of a properly executed SOA.
Being able to weld, cut your own brackets, mill/drill/tap knuckles, make your own steering linkage..etc. Those are all things that can help you keep cost down. If you have to turn your rig over to a shop to do the work, the price goes up considerably.
BESRK is offline
post #13 of 49 Old 12-26-2013, 08:45 AM
CSP
Nobody said there would be problems. Posting a picture of a CJ spring over isn't much detail either.
CSP is online now
post #14 of 49 Old 12-26-2013, 03:30 PM
L78THUMPER
2007 MK Compass
CSP theres NO need in being a smart *** ! I was just showing my jeep has been out and I have had no problems and my Jeep will go any where I want it to go! Same S**t on this forum as normal. Also I was just giving my thoughts on SOA'S and that I was very Happy with mine!
post #15 of 49 Old 12-26-2013, 03:32 PM
L78THUMPER
2007 MK Compass
CSP guys like you are why alot of people are leaving this forum. And what detail do you need on an SOA. the pic can be blown up to see closer up if needed
