SOA axle wrap example video - JeepForum.com
post #1 of 20 Old 12-25-2013, 10:08 AM Thread Starter
ScroungerLee
I just ran across this and it's the clearest video I've ever seen showing the problems with axle wrap. I like the way the tiny track bar that got added later in the video fails completely.
Enjoy!
http://youtu.be/Hv6HZVv4GUo
ScroungerLee is offline
post #2 of 20 Old 12-25-2013, 11:40 AM
CJ7nvrstk
Military Jeeper
CJ7nvrstk's Avatar
Ouch, that's a lot of wrap!
RED Friday. Remember Everyone Deployed
45 MB, 67 Commando, 85 CJ, 08 JKU, 11 JKU
CJ7nvrstk is offline
post #3 of 20 Old 12-25-2013, 11:49 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Those videos were painful to watch.. Amazing how high those pinions were climbing. I'm surprised they didn't bind/snap the ujoints.
BESRK is offline
post #4 of 20 Old 12-25-2013, 12:51 PM
SgtJensen
I cringed....throughout the entire video....
Staff Sergeant of Marines - January 2003 - Present
SgtJensen is offline
post #5 of 20 Old 12-25-2013, 01:19 PM
GB3440
1979 CJ7
Just think of the pressure on the ring & pinion gears. I can see why you should try to get all of your gearing in the trans/transfer case. I went with 4.56 gears in mine and was surprised at how small the pinion is. Makes me think...
GB3440 is offline
post #6 of 20 Old 12-25-2013, 01:54 PM
skizriz
1978 CJ7
There is a lot of force going on back there. I recently changed the rear mounts on my anti wrap bar from bushings, to heim joints. The bushing would just tear apart, and the tube that held the bushing would end up egg shaped.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #7 of 20 Old 12-25-2013, 02:21 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Wow, I thought that one was gonna go thru the floorboards!
Issues I saw on a lot of the though was how the springs were set up soft and a couple shots they looked negative arched already, and the one the bottom leaf looked installed upside down...
Rick
Cutlass327 is offline
post #8 of 20 Old 12-25-2013, 07:35 PM
Spieg8
1984 CJ8
Most springs tend to look like that after a couple years of abuse in a SOA setup. They just flat out take a beating (no pun intended).
Spieg8 is offline
post #9 of 20 Old 12-29-2013, 10:33 AM
pajadam
1987 YJ Wrangler
So what's the best setup to prevent this?
pajadam is offline
post #10 of 20 Old 12-29-2013, 11:07 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Originally Posted by pajadam
so what's the best setup to prevent this?
sua
Matt1981CJ7 is offline
post #11 of 20 Old 12-29-2013, 11:12 AM
swatson454
1983 CJ7
4-link!
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #12 of 20 Old 12-29-2013, 11:14 AM
pajadam
1987 YJ Wrangler
Originally Posted by swatson454
4-link!
Shawn
What is that?
I don't know much about suspension.
pajadam is offline
post #13 of 20 Old 12-29-2013, 11:29 AM
swatson454
1983 CJ7
http://www.fabtechmotorsports.com/suspension-101.php
Double tough
Shawn
post #14 of 20 Old 12-29-2013, 11:54 AM
pajadam
1987 YJ Wrangler
Thanks it helps alot!
pajadam is offline
post #15 of 20 Old 12-29-2013, 02:00 PM
CoryA
If you plan on going SOA build a good traction bar
Not like the one shown in the video
CoryA is offline
