Quantcast So where do you start. . . - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > So where do you start. . .
Old 01-15-2009, 07:32 PM   #1
jpd1899
1978 CJ7
So I am new to community--so please, be kind if this is a repeat question.
In terms of time and $$, what does a frame up restoration of a 78 CJ7 cost/how much time? I figured the members posting in this section could provide some type of general number.
I got a 78 CJ7 as a Xmas Present from my girlfriend. While most of you out there may be excited, I am a little freaked out, and don't know where to start.
It's a 258 4.2 L, stock throughout. There is a hole in the frame at the front of the passenger side rear leaf spring. Lot's of rust on the body and the frame. I know the engine starts (if you juice the carb), but won't idle. (I'll tackle that later). My plan is to try to bring it back far enough, to play a little with it, nothing real serious for the time being.
Any ideas of time frame and cost?
jpd1899 is offline   Reply With Quote
Old 01-15-2009, 07:50 PM   #2
gojeepin
gojeepin's Avatar
1983 CJ7
It depends on how much you'll do yourself and whether you're going to modify it. If mostly stock is what you have in mind you could do it for about $1K to $3K since it sounds like you may have serious frame and body work to do.
I did almost all my own work (other than machining the engine) but upgraded several parts and spent $8K.
I replaced:
Shocks
springs
Wheels/Tires
Transmission
Speedometer cluster
Tie rod & drag link
I rebuilt:
Engine
All new parts for axles/gears/brakes
I had a local body shop repair/paint the body $4K (my time's worth more than their's)
Vibration? Bump steer? Wandering? Read: Steering, suspension, and driveline basics. An article on how it works and where to look for problems.
83 CJ7, 4.1L 6cyl (4.0L bored .030" over), 35" tires, T-5 transmission, Dana 300 TC, Trussed AMC 20.
gojeepin is offline   Reply With Quote
Old 01-15-2009, 08:13 PM   #3
chadcarter
1983 CJ7
I'm about 18 months along right now and in the 6-7K range. I have been upgrading everything along the way though. Have about 4 more months to go.
1983 Jeep CJ-7, AMC 360 swap, TF999, AMC 20 w/ 4.10s Mosers & Detroit, Dana 30 4.10s Open. 4" BDS with 1" Daystar BL & 1" Shackle lift. 35x12.50x15 General Grabber M/T. Corner & Rocker protection by Sniper Fab, with Bumpers by GroundPounder Fab.
chadcarter is offline   Reply With Quote
Old 01-15-2009, 10:31 PM   #4
Stan99
1978 CJ7
Pics and an idea of what you want to do with it. Pics of the problem areas would also help. And just a fair worning that once you get going on it, its kind of addicting, but well worth it. I am about two years into mine and should have about 3 months left. But I have completley rebuilt everything and upgraded everything big time!
1978 Jeep Cj7 Soa, Shackle Reversle, 36x13.5x15 Irocks, 4.5 Stroker MPI, Dana 300 twin Sticked, 4.88's
Stan99 is offline   Reply With Quote
Old 01-16-2009, 05:12 AM   #5
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I think the 1K to 3K estimate was for the frame and body alone? I would venture to say that if you fixed the 2, that is where that money would end up... as for the rest, well, it all depends on where you want to end up... I have done rebuilds for a couple thousand that then needed to be redone... again, and then I did it right on some and spent anywhere from 6K to 25K... all what you want to spend and what time you are willing to put towards it, because if you don't do it yourself, just remember mechanics get $50/hour... and a FULL total rebuild will take you 400-700 hours... easily.
cb
CertifiableJeep website
'76 ORANGE CJ-5
'76 MAROON CJ-5
'78 SILVER CJ-7
'82 WHITE CJ-8
ORANGE JEEP CLUB #41
certifiablejeep is offline   Reply With Quote
Old 01-16-2009, 07:50 AM   #6
jeepskate
Welcome aboard. This is a very open-ended question and there simply is no canned answer for you...there's no cookie-cutters. Everyone starts from a different place (knowledge, skills, tools, vehicle condition) and has a different goal (spectrum from daily driver to hardcore wheeler...restoration to 'restification' to not much of the original vehicle left). These are big toys for big boys as the saying goes, and there's tons of aftermarket support as well as what you might think up/fab up yourself. The place to start is with an assesment...an assesment of your skills, willingness to tackle the project, budget, condition of the Jeep. Next comes the basic plan...how do you plan to use the Jeep when it's done, what do you want it to look like, must have items. Then you start researching an educating yourself on how to get from what your Jeep currently is to what you want it to be.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
http://www.jeepskate.net
jeepskate is offline   Reply With Quote
Old 01-16-2009, 05:06 PM   #7
jpd1899
1978 CJ7
Thanks everybody
Well, thanks everybody for the feedback. I am basically getting the general picture--a lot of time, and as much money as you want to spend, but definitely set aside at least 5k (keeping fingers crossed) to get it on the road.
As far as an assessment, I'm starting from the ground up, skills/knowlege, tools. I know the BARE minimum about vehicles, but I think I'm a pretty fast learner. This project will be the test though.
I don't think I will jump right in and start tearing things out, if they are working OK. I might start the upgrading if something needs to be replaced. Just don't have the budget right now, but ultimately, I'd like to get it to a point where its nice, but I can still drop it into a mud hole
The general plan-get it running, get it pretty.
Thanks everybody again, great intro to the forum.
Old 01-16-2009, 05:24 PM   #8
bigjoe
1977 CJ7
Welcome, I think you have got the right idea moving forward. Get yourself a shop manual and start reading. There is a ton of info on the web as well as books on Jeeps that well help your knowledge along as well. Get to know how your Jeep runs and start making a list of things that need to be addressed first for a safe and useful Jeep. Then you can move forward with an idea of how you want your Jeep to look and be used for when your done. Oh and that final look will change several times. Trust us.
Seems like everyday is a Monday.
77' CJ-7 84' CJ-7 83' Chevy K10
bigjoe is offline   Reply With Quote
Old 01-16-2009, 05:54 PM   #9
neals80
1980 CJ7
The best start was right here,,,,the best class of guys I have never met......PS pay the money and join...is is worth the 60 sec delay for the search engine when you run into a problem and have to wait for 60sec..lol...
This site is priceless...Good luck!
Neal Trombley
1980 CJ 7
SW FLORIDA
IF I WANTED A HUMMER I WOULD HAVE CALLED YOUR GIRLFRIEND!!
neals80 is offline   Reply With Quote
Old 01-16-2009, 05:58 PM   #10
Duble-it
pictures, pictures, pictures, pictures!!! put them in a photobucket account and post the link then someone will "no click" em for ya.
1986 CJ-7 that doesn't like to sit in the driveway.
LATE FOR WORK, EARLY FOR JEEPIN'
Duble-it is offline   Reply With Quote
Old 01-16-2009, 06:01 PM   #11
AbsolutXJ
AbsolutXJ's Avatar
1953 M-38
Definately post some pictures. Like neals80 said ^^, if it's been done these guys know how and what it costs. Take LOTS of pictures even if you don't post them. My vote is for a frame off restore if you have to do some work on the frame. Very interested to see your progress. Congrats on being bitten by the bug!
oh...and x2 on the membership. WELL worth the money!
BTW...where do you live at in Richmond? My parents are there and I'm only about an hour away. If you ever get stuck shoot me a PM and I'll see what I can do for ya!
Willys M38A1 - project vehicle
AbsolutXJ is offline   Reply With Quote
Old 01-16-2009, 08:08 PM   #12
gojeepin
gojeepin's Avatar
1983 CJ7
Besides getting a wealth of valuable info from the folks on this board, you can join a local club with many experienced members. I just left a great club (BESRK is in it) in Newport News, Virginia. They, among others, are in your back yard.
Old 01-16-2009, 08:10 PM   #13
Bakunin
Bakunin's Avatar
Like my old pal used to say, "We start small, or not at all."
Time flies like an arrow; fruit flies like a banana.
Bakunin is offline   Reply With Quote
Old 01-16-2009, 09:45 PM   #14
pscj5
1972 CJ5
well welcome and good luck like they said start it small and get into it then go big if you like what you doin wish my GF would by me a CJ you got a keeper lol she thinks i spend to much money on mine if you need any local help i pm'ed you my email just hit me up
If you get stuck it better be broke or you didnt hit it hard enough
pscj5 is offline   Reply With Quote
Old 01-17-2009, 11:33 AM   #15
jimdubose
1978 CJ5
i have always been told that the way to make a small fortune is to inherit a large one and then purchase and restore a CJ project jeep
jimdubose is offline   Reply With Quote
Glock Forum
