So what's a waggy 44? - Page 2 - JeepForum.com
post #16 of 31 Old 08-29-2011, 01:11 PM
robert1973
1977 CJ7
Sorry. Meant outside of disc. Am referring to my front axles. My rear axle is little over 57" wide from the 77 wagoneer
ΜΟΛΩΝ ΛΑΒΕ
The Right is wrong and the Left is stupid
robert1973 is offline
post #17 of 31 Old 08-29-2011, 03:34 PM Thread Starter
mopar346
Very interesting, so what is the width of a wide track CJ, I measured yesterday with the wheels on it and I got roughly 56 inches. Is that correct?
Careful your character's showing
mopar346 is offline
post #18 of 31 Old 08-29-2011, 08:29 PM
robert1973
1977 CJ7
This is what my front Dana 30 reads and rear 20 reads
ΜΟΛΩΝ ΛΑΒΕ
post #19 of 31 Old 04-29-2014, 06:48 AM
Black_Krawler
Waggy Identification
I picked up a Waggy 44 front, the seller told me he thinks it's out of a 77 wagoner...
It has locking hubs, 5 bolt patter axles, calipers.......
QUESTION:: I see no numbers on the housing, where can I find some sort of identification on this waggy 44? Without wasting tons of time looking at unknowledgeable info on the web.
Black_Krawler is offline
post #20 of 31 Old 04-29-2014, 09:10 AM
CSP
A 77 Wagoneer would have six wheel lugs, not five.
The BOM (bill of materials) number is stamped into the drivers side axle tube just to the right of the pumpkin as you stand in front of the vehicle. They are often hard to find, but the stamping is there. Do a Google search on "Dana BOM" and you can find websites to look up the number as well as a diagram exactly where it's located. I'd find the sites for you, but I've done it just too many times already.
CSP is offline
post #21 of 31 Old 04-29-2014, 09:13 AM
texasdave
texasdave's Avatar
1980 CJ7
You can take the numbers from the axle tubes the rear numbers are on the passenger side I believe and the the front can be either side and cross reference them to a Bill of materials (BOM) site from Dana-Spicer and it will tell you the specifics. One thing that you need to know is that on some Wagoneer rears the differentials are offset for drivetrain and gas tank clearance and may not work in a CJ without modification.
How To Identify A Dana Spicer Axle - TheRangerStation.com
http://www.therangerstation.com/tech...ana_axle.shtml
texasdave is offline
post #22 of 31 Old 04-29-2014, 12:01 PM
Black_Krawler
Copy that- Thank you !!!!!!
It must be an 87 Wagoneer .....Can't find any numbers anywhere !!!
post #23 of 31 Old 04-29-2014, 12:03 PM
Black_Krawler
Thanks Texas, If I could only find those numbers !! Grrrr !
post #24 of 31 Old 04-29-2014, 01:28 PM
CSP
Where are you getting that it must be from an 87 Wagoneer? An 87 would have the pumpkin on the drivers side opposite of a CJ. Any '74 and up Wagoneer is six lug if that's where you're getting 87 from.
You'll probaby have to remove some paint to find the stampings.
CSP is offline
post #25 of 31 Old 04-29-2014, 03:27 PM
Black_Krawler
I never mentioned CJ (it's going in a ZJ)
I mentioned 87 because the seller did not know, he assumed it was either 77 or 87 and which I had seen the 77 was 6 bolt lug pattern, I at that point assumed it was from an 87 wagoner
post #26 of 31 Old 04-29-2014, 04:38 PM
Black_Krawler
The only number I can find is on the knuckle, and it reads C38535 not sure if anyone can help me with that number...
post #27 of 31 Old 04-29-2014, 06:38 PM
CSP
You realize that this is a CJ forum right? We assume any mods are going on a CJ unless you state otherwise.
Since you obviously looking nowhere near in the right spots here's the diagram I said I wouldn't post again. Notice that the BOM is on the long axle tube on a front axle.
More info found here:
http://77cj.littlekeylime.com/BOM_Info.htm
CSP is offline
post #28 of 31 Old 04-29-2014, 07:24 PM
BlueRubiconrich
I put a 1980 Scout Dana 44 front under my 86 CJ7 had it cut down 3 5/8"s to CJ7 wide track width. same bolt pattern as a CJ 5 on 5 1/2. used my CJ's brakes and old school 6 bolt hubs. I had the knuckles clocked 10 degrees
I have a 4" lift. I had a chromemolly shaft cut for the long side. It has the bigger Ujoints found in the later YJ Dana 30's ,CJ Dana 30's had the small ujoints.
The waggy tubes are thicker then the Scouts, but the Scout dana 44's are thicker then Rubicon Dana 44s.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #29 of 31 Old 04-29-2014, 07:42 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
.. here's the diagram I said I wouldn't post again.
I almost fell out of my seat laughing.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #30 of 31 Old 04-30-2014, 07:35 AM
Black_Krawler
Yes I know it's a CJ forum, it could be a star-trek forum, it wouldn't matter, considering *the component* we are referring to is in this forum (waggy 44) And just because I posted the knuckle ID number, doesn't mean that I'm obviously looking in the wrong place.. I have looked from knuckle to knuckle in a 360* radius and only spotted the knuckle ID. I assume at this point, who-ever ground down the old brackets from the housing, must have ground the BOM.
Thank you CSP, I understand that your efforts do become exhaustive, I used to run my own forum years ago, I know a lot of it becomes repetitive simply because ppl are lazy, I assure you that 'I don't fall short in that department' and I do appreciate your help and effort set forth... Thank you BK
Building a waggy 44 92XJT Jeep CJ Forum 7 01-27-2010 10:16 PM
86 CJ7 + 85 G Waggy sail78385 Jeep CJ Forum 1 07-22-2008 10:30 PM
78 Waggy 44's In With D18 CJGUY Jeep CJ Forum 12 07-07-2007 11:42 AM
Converting Waggy D44 to 5x5.5 Matt in TN Jeep CJ Forum 1 12-29-2006 11:00 AM
Waggy D44 in CJ?? cyclic17 Jeep CJ Forum 4 08-29-2006 05:27 PM
