Snorkel on a CJ - JeepForum.com
post #1 of 27 Old 09-20-2011, 02:11 PM Thread Starter
tdkask
Snorkel on a CJ
So I took my '80 CJ7 I purchased back in April out for it's first real "offroad" adventure. We were out on the Outer Banks of NC for a local club sponsored beach cleanup not long after Hurricane Irene and there were a lot of deep "puddles" on the roadways, several 3ft or so deep, so obviously we saw an opportunity to go play. Once, only briefly, I got a little water in the carb and spit steam out the back for a minute or so. This was probably because I was unexperienced and went a little too fast through the water (maybe 10-15 yards across). Either way, with 33's and about 4" lift, I did get a little water ingested.
So I want to know at what point I would benefit from a snorkel? I hate the idea of a Safari or similar snorkel on a CJ, so would have to make one that looked more correct. Does it even make sense? By the time I get water to the top of my carb isn't it a point where the whole engine (including alternator and distributor) are having other problems anyway? At what point am I just not going to make it any deeper without more lift/tire?
EDIT: would it be helpful to just use a "riser" to raise air cleaner to barely clearance hood? (258 with MC2100) Or maybe a riser between intake and carb to raise carb and create better velocity into intake?
Finally, and suggestions for a style or snorkel that looks classic on a CJ? Thanks for any info/suggestions.
80 CJ7_360_32RH_D300_44/9"(4.56)_custom bumpers/cage
4" lift,tube fenders,comp cut_37s on H1 rims
tdkask is offline
post #2 of 27 Old 09-20-2011, 04:19 PM
Sedorbrian
You can run it through the firewall, ive seen it done before. The cab usually stays dryer, so if it comes ought near the heater or something, it would work without the big snorkel going up the windshield. Im building a metal one that doesnt actually conect to the windshield, but alongside it, so i can still fold it down.
Sedorbrian is offline
post #3 of 27 Old 09-20-2011, 04:22 PM
BrandonJames
1974 CJ5
Have fun ripping it off on a tree branch
BrandonJames is offline
post #4 of 27 Old 09-20-2011, 04:37 PM Thread Starter
tdkask
Originally Posted by Sedorbrian View Post
You can run it through the firewall, I've seen it done before. The cab usually stays dryer, so if it comes ought near the heater or something, it would work without the big snorkel going up the windshield.
I don't expect to even ever fold mine down, I just don't like the looks of a more modern design on my CJ... just personal preference. And not sure what DIY would look right and not cobbled together. I thought about the inside-the-cab approach, but bet it'd be really loud.
Again, at what point can I expect failure of other components? I mean, there is so much that is same height or lower than my carb... but nonetheless, I made it through.
What approaches have been tried, and with what results? Pics?
Thanks again.
tdkask is offline
post #5 of 27 Old 09-20-2011, 04:49 PM
hybridmoments
1978 CJ5
If you weren't worried about altering anything I feel like the most original design without modernizing the CJ look too much would be a humvee style snorkel.
hybridmoments is offline
post #6 of 27 Old 09-20-2011, 04:53 PM Thread Starter
tdkask
yeah, I was liking that idea a little... but thought I might need it a little higher, as the water rushes over the hood a little at the same time it's high enough to get into the carb inside the engine bay. What's the experience here? Anyone tested these out relative to just carb/air cleaner?
tdkask is offline
post #7 of 27 Old 09-20-2011, 06:06 PM
Erik719
1983 CJ7
That is totally bad @$$!! Do you have a write up on how you did it? I want to copy it!
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline
post #8 of 27 Old 09-20-2011, 06:11 PM
ctappan94
1983 CJ7
that's on a JK, right? That windshield wont fold down and if you put that on a CJ, wont it not allow you to put the windshield down without removing the snorkel?
ctappan94 is offline
post #9 of 27 Old 09-20-2011, 06:19 PM Thread Starter
tdkask
You are right... on a CJ it would hinder the folding down of the hood. I don't think it'll be an issue for me, especially with the YJ family bar and windshield spreaders.
tdkask is offline
post #10 of 27 Old 09-20-2011, 07:18 PM
Erik719
1983 CJ7
Yeah, guess you are right. Damn!
'83 CJ7 - Donkey
Erik719 is offline
post #11 of 27 Old 09-21-2011, 02:07 AM
BagusJeep
1981 CJ7
This is the one Chris78CJ7 came up with, it is real bad (in a very bad way). It would work unless a wave was coming at you across the bonnet, in which case you may want to turn it round, easy enough as it is plastic drain pipe. I also imagine the top section would unplug fairly easily to lower the windscreen.
An upgrade to this would be a cowl vent cap on top instead of that 90 degree bend, they come in black as well as grey and would be all matching and would allow enough air to get to the filter. You could carry a 3 foot length of pipe with you to extend it for really really deep river crossings.
It looks uncannily like that JK above and you could also write RAIDER on it or something and pretend it was one of those expensive store bought snorkels.
The more I look at this the more excited I become......... time for cold shower.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #12 of 27 Old 09-21-2011, 02:31 AM
John Strenk
John Strenk's Avatar
1976 CJ5
Yes I think it should point the other way just like the fresh air vents that sit in the same location. Anyone who drives a CJ and looks at thier hood in a rain storm will easily see the rain drops going forward.
I think if you want that Classic CJ look you need to cut out the hood \
Still should work on getting your distributor and alternator and axle tubes waterproof also. JH uses an air compressor to keep positive air pressure in these parts.
Of course don't go in to DEEP.
John Strenk is offline
post #13 of 27 Old 09-21-2011, 02:39 AM
ex m38a1er
Τhat's what i did on my m38a1 many years ago.
You can't get more original
" H TAN , H EΠI TAΣ"
'WHO DARES,WINS'
ex m38a1er is offline
post #14 of 27 Old 09-21-2011, 05:38 AM
waterdowg
What is the minimun size tube that can be used for to make a snorkle. Got some ideas, but need to know the minimum size is.
waterdowg is offline
post #15 of 27 Old 09-21-2011, 06:25 AM
poppatello
Don't forget another major benefit to a snorkel. Giving the engine much needed cooler air. It will run much better giving you the correct HP, torque and MPG that you should be getting! My issue is trying to figure out how to mount them to the carb. We need more close up view of this...
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
Snorkel Pink-Monster Jeep CJ Forum 6 08-24-2010 02:03 PM
WHAT snorkel? FIT? bigred78 Jeep CJ Forum 0 05-13-2010 08:57 PM
snorkel cj 258 stonewallmp5 Jeep CJ Forum 6 06-20-2007 01:31 PM
Snorkel for CJ supraman1990 Jeep CJ Forum 3 03-04-2007 07:43 PM
snorkel nealcavanaugh Jeep CJ Forum 28 02-09-2007 12:14 PM
