Smoking wire! - JeepForum.com
post #1 of 5 Old 07-09-2011, 05:24 PM Thread Starter
Taylorettel
1980 CJ7
Smoking wire!
Alright JF, Ive gota duzy here with my '80 Cj7
I installed a set of new Delta Hyperwhites that run the H4 bulbs and at 60/55
watts. After fixing a faulty ground, i left the headlights on to admire them. I
got back in the cab and the red w/ white wire was smoking and melting the
plastic on the harness for the headlight switch! It only smokes when I turn on
my brights though. After examining my diagram, i found that its my *foot dimmer switch feed*.so my questions are, is my dimmer switch faulty? or do i need bigger wire to make up for the new headlights? and how do I run relays for my new deltas?
thanks in advance!
Taylorettel is offline
post #2 of 5 Old 07-09-2011, 05:37 PM
WindKnot
1977 CJ7
You're pulling too many amps through the switch. Consider strongly a headlight relay under the hood and running heavier gauge wire for both 12V feed through the relay AND ground back to the battery or at least a ground buss. I DON'T KNOW THE FORMULA, but I'd run 10 gauge wire considering you're pulling about 700 watts.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #3 of 5 Old 07-09-2011, 05:43 PM Thread Starter
Taylorettel
1980 CJ7
*update*
went out and checked again. This time , no smoke and no heat on the said wire. Now both high beams work and only left low beam works.
post #4 of 5 Old 07-09-2011, 06:27 PM
Skerr
Have a look at this thread. It discusses the use of relays. I didn't read through the whole thing, but knowing Jeephammer, he probably explains in detail how to install. DON'T run your headlights the way you have them wired. You could end up burning down your Jeep!
http://www.jeepforum.com/forum/f8/he...t-mods-686559/
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5 of 5 Old 07-10-2011, 07:13 AM
CJunk
The wiring upgrade is a must. Look at the above link. Once you get all the parts on hand it isn't as confusing to do.
I did this a while back and the difference is unbelievable.
CJunk is offline
headlight switch , relay , smoke , wire
Headlight wire smoking! SAH_80_CJ7 Jeep CJ Forum 23 01-28-2011 04:19 AM
Converting Brake Pressure Switch from 2-Wire to 1-Wire Configuration checkman808 Jeep CJ Forum 4 01-12-2010 11:22 PM
smoking coil terminal (negative green wire) jimdubose Jeep CJ Forum 3 08-23-2009 02:31 PM
Wiper Motor Wire (3-wire vs 4-wire) TetanusCJ7 Jeep CJ Forum 0 07-18-2009 07:15 AM
Calling on Delco Alt Experts..Which is better: 1-Wire or 3-Wire?? hfjeff Jeep CJ Forum 2 04-05-2006 03:07 AM
