Smoking CJ7 - JeepForum.com
post #1 of 3 Old 03-08-2009, 04:06 PM Thread Starter
Subman
Smoking CJ7
I have a few questions. I bought a CJ7 that was supposed to have had a rebuilt engine. Inline 6 cylinder. The previous owner said nothing was done to the head. It had a small 2 barrel carb on it, but, not stock. It smoked pretty bad, but, it appeared to be running rich. I replaced the carb with a new weber 36 DGEC. I also did the nutter bypass on it. I don't think there is any wiring hooked up, except the bare minimum. No computer hooked up at all. All vacuum disconnected and plugged, except the bare minimum. Set timing to spec, Idle set to spec.
It idles good, takes gas good, does not diesel on cutoff. you can see a slight amount of smoke at idle, but, it is like a fogger when you take off. After you get up to speed, the exhaust looks like it does at idle. The smoke appears to be white in color. I have not done any adjustment from factory settings as per instructions. I installed new plugs, and new valve guides also. I have not pulled the plugs yet to see what they look like. Still hot.
So what do you think? Does it sound like it is running rich from fuel, or does it sound like oil? Maybe water!
Tell me what you think, please, I apprecited it.
Terry
Subman is offline
post #2 of 3 Old 03-08-2009, 06:38 PM
mjp83
2011 JK Wrangler
My L-6 ran rich most of the time, and it was black smoke.
Blue smoke indicates burning oil, and it usually would get better as the motor warms up.
The white smoke sounds like you have a leaking head gasket, and you are seeing water being burned off.
Pull your plugs, white residue would be antifreeze and and indication of a leaking head gasket. A carboned up plug is too rich, and a oily plug would indicate burning oil.
My guess is head gasket.
mjp83 is offline
post #3 of 3 Old 03-08-2009, 06:42 PM
No_Bs
1977 CJ5
Sounds like a head gasket, whoever rebuilt it either put it on sloppily or the head or block could be warped. If a plug is completely clean, its seeing antifreeze.
1977 Cj5, 258, T-18, 2.46:1 Dana 20, 2.5" BDS lift, OBA, 38.5's. Chevy 60 frt, 14b Rear, Full hydro, 102"wb, full DOM cage.
No_Bs is offline
AMC 360 Smoking jp360cj Jeep CJ Forum 5 03-29-2009 09:19 PM
258 Smoking jmdkb12 Jeep CJ Forum 11 03-22-2009 12:30 PM
Smoking and really hot dhavard Jeep CJ Forum 15 12-11-2007 02:19 PM
Smoking. What are the possibilities? ClarkGriswold Jeep CJ Forum 13 03-24-2007 08:49 AM
Smoking 304 arkiemurph Jeep CJ Forum 14 03-09-2007 10:05 AM
