Smoking after rebuild - 86 4.2 - Page 2 - JeepForum.com
post #16 of 22 Old 05-07-2012, 08:40 AM
swatson454
1983 CJ7
Originally Posted by PWRSPD View Post
Ring gaps lined up is almost always a sign that the cylinder is out of round. Rings are supposed to spin on the pistons.
^^^Agreed.
Not so great machine shop. AWESOME mechanic
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is online now
post #17 of 22 Old 05-07-2012, 09:02 AM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Maybe they ran it across the border to Mexicali for the machining
LT1CJ7 is offline
post #18 of 22 Old 05-07-2012, 09:08 AM
swatson454
1983 CJ7
Could be.
I suppose it's possible that they weren't able to stuff 6 illegals in perfectly round bores
post #19 of 22 Old 08-21-2013, 04:40 PM
rexbka1865
1983 CJ7
Check this out to see if it is similar to your issue. Thanks.
LOOKING FOR IDEAS ON WHAT MAY HAVE HAPPENED. I have a 83 CJ7 with a 258 4.2, T5 trans, 4.10 gears and 33" tires. History: I had the engine overhauled due to a compression/leak down issue that I thought contributed to the engine dying as it came to a stop (often), but it would crank up fine to continue the journey. While at the rebuilder (a reputable shop in Bossier City, LA), the cylinders were bored .040 over and I decided to upgrade the cam to a Comp Cam X4254H Xtreme 4x4. I made sure to remind the engine shop that Comp had a kit and please follow all suggestions that Comp may have. After I reinstalled the motor into the Jeep, we had PROBLEMS! 1) Valve train rattle at all engine speeds. 2) Occasional "thump" noise coming from timing chain cover area, and 3) As soon as oil pressure developed after initial crank, black/blue/gray smoke would pour out the exhaust. I took the engine back to the rebuilder and there diagnosis is that the pistons had been "washed" by too much fuel. (I think this is a crock, as I did not make any changes to my Weber Carb from prior to the rebuild). Also they said the cam lobes were worn. All this "damage" was to have occured from the approximate run time since rebuild of 1 HOUR. It had one trip down the road for about 10 miles round trip to "seat" the rings as my mechanic thought it needed, no help. The other time was typical service bay time. Any ideas on how this damage could have happened? The rebuilder wants to blame me and I think he screwed up. Who could it be?
rexbka1865 is offline
post #20 of 22 Old 08-21-2013, 07:11 PM
LumpyGrits
Hi, you do know that was a 2 1/2 year old thread.
Sounds like small claims court in your future.......
Why such a radical cam for a stock engine?
Also, Comp Cams ain't the best......
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #21 of 22 Old 08-21-2013, 07:21 PM
MoC
Who in Bossier rebuilt it?
If it was Kittlers I know 1 other member here who had a rebuild engine die right after they got it and they blamed it on him..
MoC is offline
post #22 of 22 Old 08-21-2013, 08:27 PM
swatson454
1983 CJ7
You can't be messing around with modern oils off the shelf these days. Comp Xtreme lobes are pretty aggressive so the break-in procedure is critical. If the builder didn't break the cam in then I'm not real sure what recourse the customer actually has. That really sucks.
Shawn
engine help , rebuilt engine , smoking
258 smoking Surf2679 Jeep CJ Forum 2 05-23-2010 01:01 PM
AMC 360 Smoking jp360cj Jeep CJ Forum 5 03-29-2009 09:19 PM
258 Smoking jmdkb12 Jeep CJ Forum 11 03-22-2009 12:30 PM
Smoking CJ7 Subman Jeep CJ Forum 2 03-08-2009 06:42 PM
Smoking 304 arkiemurph Jeep CJ Forum 14 03-09-2007 10:05 AM
