Smoking after rebuild - 86 4.2 - JeepForum.com
post #1 of 22 Old 04-13-2012, 11:23 PM Thread Starter
PJCJ7
I'm having my 1986 CJ-7 rebuilt. It has the 4.2 engine. It was a complete engine rebuild and it's smoking from the exhaust. The mechanic has had a lot of experience with jeeps but is at a loss for why. He said that for some reason the spaces on the rings keep getting aligned after it's reassembled and run which is allowing oil past the rings into the cylinder. He's checked all the machining that was done and it's all within specs. He's also checked with other mechanics to see if they've ever run into this problem to no avail.
Figured I'd throw this out there to see if anyone else has run into this before and have an idea why. He said he's going to try a different block and if it's still smoking he's going to give it back to me at no cost for any work done since he hasn't been able to solve the problem.
PJCJ7 is offline
post #2 of 22 Old 04-14-2012, 06:58 AM
Bubba Ray
Never seen this before but it sounds like your mechanic is treating you fairly.
Bubba Ray is offline
post #3 of 22 Old 04-14-2012, 07:11 AM
Shiftace
1977 CJ5
Yep, hang on to that mechanic!
The only thing I could imagine that would cause this would be the cylinders being out of round.(and. yes, I'm pulling that out of thin air. I truly have no clue...) Machining would have corrected this.
Originally Posted by gpets View Post
...it is perfectly acceptable to take a sawzall to anything you can't figure out, that is how we all learn.
Shiftace is offline
post #4 of 22 Old 04-14-2012, 07:51 AM
stamp32
Possibly the piston rings were not aligned properly (staggered) and oil is seeping through the openings in the rings. Just throwing that out there. I have seen it before.
stamp32 is offline
post #5 of 22 Old 04-14-2012, 09:14 AM
26679cj7
1979 CJ7
A completre engine job would have used new pistons right,maybe they got the engine kit wrong,a newly bored and honed block should be ok if it is within specs,I would check to see if pistons or rings are right.
26679cj7 is offline
post #6 of 22 Old 04-14-2012, 09:35 AM
titomars
1981 CJ7
i would say the rings are wrong. sounds like they don't have enough tension against the walls causing them to spin. And...... if the rings are wrong what about the pistons? Has your mechanic actually pulled any pistons out? Do you have access to the part numbers of the rings and pistons used?
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #7 of 22 Old 04-14-2012, 11:29 AM
gmakra
Unless you pulled it apart to look at the ring end gaps I would say somebody is guessing.
How many miles on the engine?
Are they chrome rings, cause they take a while to seat.
gmakra is offline
post #8 of 22 Old 04-14-2012, 12:34 PM
248107
1983 CJ7
This on all the pistons?I've seen this happen on piston air compressors if the rings were installed upside down.
248107 is offline
post #9 of 22 Old 04-16-2012, 08:45 PM Thread Starter
PJCJ7
I'm not sure if it's happening on all the pistons. I'll ask him. He's said he's staggered the rings when he placed the pistons into the engine but when he's pulled them out after running the engine, and it is still smoking, the gaps in the rings are aligned again. He's tried upgrading to better rings with the same result. He's had to pull the head off several times after reassembling it because it was still smoking. He's expressed that he's never seen this before and he's at his wits end trying to figure it out. Trying a different rebuilt block is his last attempt to correct the issue. I'll also double check about whether he's got the right pistons and rings. As far as mileage, it's well over 100k but like I said, it was just completely rebuilt.
Thanks for the responses, really appreciate the help.
PJCJ7 is offline
post #10 of 22 Old 04-17-2012, 12:04 AM
parker007
1977 CJ5
Was the engine smoking before? and exactley what was installed and what was machined? does it smoke? has the engine been run under load yet? somtimes it takes loading engine to seat rings. what hone method was used on cylinder walls? and who rebuildt head what valve stem seals were used?
parker007 is offline
post #11 of 22 Old 04-25-2012, 06:24 PM Thread Starter
PJCJ7
So I got the jeep back. He replaced the block and it's not smoking anymore. Unless the machine shop screwed up my block when they did the work I can't really see why it made the difference. My mechanic is going to have my old block checked by a different machine shop.
PJCJ7 is offline
post #12 of 22 Old 04-25-2012, 07:04 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Your mechanic gets props !!!
Who and where is he located.
I'm sure a few of us would be able to refer some work to him.
LT1CJ7 is offline
post #13 of 22 Old 05-06-2012, 11:58 PM Thread Starter
PJCJ7
It was Figueroa's Auto in El Centro, Ca.
PJCJ7 is offline
post #14 of 22 Old 05-07-2012, 05:05 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Let us know if you, or your mechanic, ever figure out why the original engine smoked.
I have nightmares over the same thing happening on my 360 build.
Matt
Matt1981CJ7 is offline
post #15 of 22 Old 05-07-2012, 07:07 AM
PWRSPD
Ring gaps lined up is almost always a sign that the cylinder is out of round. Rings are supposed to spin on the pistons.
PWRSPD is offline
engine help , rebuilt engine , smoking
258 smoking Surf2679 Jeep CJ Forum 2 05-23-2010 01:01 PM
AMC 360 Smoking jp360cj Jeep CJ Forum 5 03-29-2009 09:19 PM
258 Smoking jmdkb12 Jeep CJ Forum 11 03-22-2009 12:30 PM
Smoking CJ7 Subman Jeep CJ Forum 2 03-08-2009 06:42 PM
Smoking 304 arkiemurph Jeep CJ Forum 14 03-09-2007 10:05 AM
