Smoking 304 - JeepForum.com
post #1 of 15 Old 03-08-2007, 09:50 AM Thread Starter
arkiemurph
Smoking 304
Started pretty soon after I put Edelbrock intake on. She's smoking only out the left tailpipe, very light colored smoke, grayish white. Also wants to foul out the first plug on the drivers side. So how do I figure out if it's rings or intake leakage or head gasket?
Murph
PS--Has to run a few minutes, before it starts to smoke. Then if you gun it a bit, it'll kill every mosquito in the state!
arkiemurph is offline
post #2 of 15 Old 03-08-2007, 10:01 AM
fuzz401
1978 CJ7
sounds like you have a leak on the front driver side
did you try to tighten the intake bolts up?
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 15 Old 03-08-2007, 10:19 AM Thread Starter
arkiemurph
Yep
I retorqued them yesterday, then started it up and it was smoking just as bad. I guess if it blew out some gasket sealant while they were loose, tightening up wouldn't help a whole lot.
Murph
post #4 of 15 Old 03-08-2007, 11:03 AM
fuzz401
1978 CJ7
then pull the intake and install a new gasket
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #5 of 15 Old 03-08-2007, 11:17 AM Thread Starter
arkiemurph
Well, if I knew for sure that's what it was, I would.
Murph
post #6 of 15 Old 03-08-2007, 11:24 AM
fuzz401
1978 CJ7
1st plug on the driver side is next to the intake runner for # 1 cyl. most like it is seaping into the runner every thing worked befor the intake swap? - did you use anything to seal the water ports in the intake? or the runners for the heads?
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #7 of 15 Old 03-08-2007, 12:26 PM Thread Starter
arkiemurph
Yea, it worked fine, just smoked a little bit. I did run a bead around each port on both sides of the pan gasket. I sure HOPE it's the intake!! I did NOT ever check the torque after the initial install, I guess that aluminum expanded and shrunk or something, cause they were torqued right, but when I checked them yesterday, they were around 15-20 ft-lbs and were supposed to be 40-45.
Murph
post #8 of 15 Old 03-08-2007, 01:44 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
they will loose torque after the first few heat cycles..dew to the gaskets shrinking by the heatThats why its imperitive to retorque them at least 2 times..I often retighten after a few hours and about a week,just to be sure..I would pull it off replace the sealsseal the water passge ports and tighten them down with the proper tightning sequence..I downt know if any intake bolts go in a 304's water passage in the head but if they do its wise to put some sealer on the threads..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #9 of 15 Old 03-08-2007, 02:01 PM Thread Starter
arkiemurph
Thanks Scrambeled, when I redo the intake, I plan to retorque every 5 minutes!!!
Can you reuse the valley pan gasket?
Murph
post #10 of 15 Old 03-08-2007, 02:18 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
:hahaha: yj
post #11 of 15 Old 03-09-2007, 08:48 AM Thread Starter
arkiemurph
After talking to a bud, I'm pretty sure it's the gasket (intake). Does anyone know if you need a special gasket when replacing the stock intake with the aluminum Edelbrock?
Murph
Thanks in advance!
post #12 of 15 Old 03-09-2007, 08:50 AM
fuzz401
1978 CJ7
just the valley pan gasket
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #13 of 15 Old 03-09-2007, 08:51 AM
fuzz401
1978 CJ7
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #14 of 15 Old 03-09-2007, 09:27 AM Thread Starter
arkiemurph
Okay, thanks Fuzz and Scrambeled. I'm gonna try to jump on it this weekend and "get er done"! Appreciate the tech help!
Murph
TGIF
post #15 of 15 Old 03-09-2007, 10:05 AM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
I have always had good luck with the felpros ..
:hahaha: yj
AMC 360 Smoking jp360cj Jeep CJ Forum 5 03-29-2009 09:19 PM
258 Smoking jmdkb12 Jeep CJ Forum 11 03-22-2009 12:30 PM
Smoking CJ7 Subman Jeep CJ Forum 2 03-08-2009 06:42 PM
Smoking and really hot dhavard Jeep CJ Forum 15 12-11-2007 02:19 PM
Smoking. What are the possibilities? ClarkGriswold Jeep CJ Forum 13 03-24-2007 08:49 AM
