Smoke from Carb? - JeepForum.com
post #1 of 4 Old 02-04-2013, 01:56 PM Thread Starter
ColdSteel85
1982 CJ7
Smoke from Carb?
82 CJ 7 when I shut it off I notice smoke coming out top of the carb? Is this normal?
ColdSteel85 is offline
post #2 of 4 Old 02-05-2013, 02:30 AM
John Strenk
John Strenk's Avatar
1976 CJ5
No, not normal.
Were exactly is it coming from?
John Strenk is offline
post #3 of 4 Old 02-05-2013, 06:47 AM Thread Starter
ColdSteel85
1982 CJ7
The smoke is coming out the top just underneath the air filter. If I take the filter off smoke comes out top
of carb for 30 sec to 1 min after shutting jeep off. It seems to be running normal though? Any ideas? Some one told me it could be just a little extra gas burning off after shutting it off? Thanks.
post #4 of 4 Old 02-05-2013, 07:10 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Most likely it's fuel leaking into the intake that is causing the smoke.
The source of the leak could be a worn needle and seat, a small crack in the float bowl, a warn throttle shaft, or too much fuel pressure.
Good luck,
Matt
Matt1981CJ7 is offline
