Smoke - JeepForum.com
post #1 of 5 Old 09-09-2012, 06:47 PM Thread Starter
rarud
Smoke
I have a 86 258 4.2l. I have nuttered it. I have set lean mix. I have set timing 8 BTC. Starts right up. at idle no smoke. reved it smokes like a teepee. did not start until today when I reset timing and adjusted carb. I am fixing to pull pcv valve and see if it smokes the same out of the valve cover. I read a previous thread where it was noted that carb being out of adjustment might make it smoke. I pulled spark plug and no oil or grease on plug. any suggestions would be much appreciated.
Robert
rarud is offline
post #2 of 5 Old 09-10-2012, 12:21 PM
tevans59
tevans59's Avatar
1979 CJ7
Google the color of the smoke. that sometimes will tell you what issues you have...
tevans59 is offline
post #3 of 5 Old 09-10-2012, 11:31 PM
1986cj
If it is coming out of the tailpipe when you get on it and is somewhat of a blue color, you most likely have bad rings. Bad valve or guides it would smoke at idle also. Do a simple compression test. Easy to do and will tell you what is going on if it smokes like a teepee.
1986cj is offline
post #4 of 5 Old 09-11-2012, 02:03 AM
BagusJeep
1981 CJ7
Did it smoke previously?
If light blue smoke that hangs about it is oil, if white and disappears can be water or fuel.
Oil will come past valve guide seals or rings. Water through head gasket or crack. Fuel is a carb adjustment issue.
It may smoke when cold but not when hot.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #5 of 5 Old 09-11-2012, 03:03 AM
RWise
1981 CJ5
has it been setting?
RWise is offline
231 smoke problem challieboy27 Jeep CJ Forum 2 02-23-2011 01:37 PM
smoke! 79jeepincj7 Jeep CJ Forum 4 08-23-2010 10:21 AM
Too much smoke..please help Bill Ruppert Jeep CJ Forum 3 08-10-2009 11:47 AM
she's blowin smoke texcj7 Jeep CJ Forum 6 06-03-2007 08:27 AM
Smoke when give it gas nightstalker5.0 Jeep CJ Forum 2 02-23-2007 05:38 PM
