Smitty Center Console Advice - JeepForum.com
post #1 of 19 Old 03-21-2012, 09:47 AM Thread Starter
tamu83cj
1983 CJ7
Anyone running this console, picture below? I want to know:
1. Could I easily take off these plastic cup holders? Do they glue or screw on?
2. Would it be possible for me to cut holes and mount speakers in the back of this box? Preferably stacked top and bottom.
3. What is the general quality of the box, is it waterproof (does the top have a rubber seal)?
Thanks for the input.
tamu83cj is offline
post #2 of 19 Old 03-21-2012, 10:02 AM
MrWonderful73
I have it and it is a nice console.
1. not sure haven't tried.
2. that shouldn't be a problem. it is pretty heavy gauge steel might be tough to cut a nice hole in.
3. I'm very happy with the quality, very sturdy. No rubber gasket but the lid is lipped over the edge of the box so unless you drive through a car wash it should stay pretty dry inside.
MrWonderful73 is offline
post #3 of 19 Old 03-21-2012, 10:06 AM Thread Starter
tamu83cj
1983 CJ7
Thanks for the feedback Mr. W.
tamu83cj is offline
post #4 of 19 Old 03-21-2012, 11:29 AM
silentmike29
1986 CJ10
i would go with the tuffy...i have one and its really durable and looks awesome
silentmike29 is offline
post #5 of 19 Old 03-21-2012, 11:45 AM
PatsCJ5
1979 CJ5
I have the smitty, I like it. I put it in in 2007 to replace a flimsy wooden one the PO had installed. Its nice and sturdy, the finish hasn't chipped off that I've noticed and it is water tight, it spent most of a winter in south dakota with only a bikini top outside and everything stayed dry inside the console.
I'm not sure about taking the cupholders off, I can take a look at mine and see how they are attached. You should be able to mount speakers inside if you cut holes for them (guess it wouldn't be as water tight then).
PatsCJ5 is offline
post #6 of 19 Old 03-21-2012, 12:08 PM
SleeperCJ
1983 CJ7
I would recommend the tuffy as well. Had mine for maybe 12 years or more. Very good, sturdy. The cup holder on it is metal and removable and can be mounted in the front or rear. Looks like it is about the same dimension and it's padded. The cup holder on the tuffy is conveniently the size of a standard can cozzie.
SleeperCJ is offline
post #7 of 19 Old 03-21-2012, 12:58 PM
Jacoby22
1983 CJ7
yes the cup holders do come out 2 phillip screws 1 on each cup holder, and i believe theres nuts on the bottom of the screws. its kinda a pain to get out when the console is bolted in lol.
Jacoby22 is offline
post #8 of 19 Old 03-21-2012, 01:07 PM Thread Starter
tamu83cj
1983 CJ7
My thought was to take off those cup holders and install some tuffys.
tamu83cj is offline
post #9 of 19 Old 03-21-2012, 01:10 PM
silentmike29
1986 CJ10
I put my amp in my tuffy, and i am going to bolt it to the back. I want to get a tuffy rear storage locker, but its like $692!!! I am not sure if i want a back seat or a lock box...anyone have this dilemma?
post #10 of 19 Old 03-21-2012, 01:26 PM
DVR
I have both-
The tuffy is constructed better but that's not what the op asked about.
Smitty is a good value for the money. Mine is showing some minor surface rust after a year. The cup holders are a joke. Seatbelt hardware will cut you. Come up with a better solution than what they offer.
question:
#1 yes
#2 yes
#3 better than you would expect for the price
DVR is offline
post #11 of 19 Old 03-21-2012, 01:39 PM Thread Starter
tamu83cj
1983 CJ7
With DVRs review I might as well spring for the Tuffy. No need to bleed more on my jeep.
tamu83cj is offline
post #12 of 19 Old 03-21-2012, 03:14 PM
PROJECT 23
Too bad you live so far away as I have a black Tuffy center console that I'm looking to get rid of. It's the standard version without the stereo mount.
I'm looking to get the Tuffy with the stereo mount, but have to get rid of this one first.
PROJECT 23 is offline
post #13 of 19 Old 03-21-2012, 03:39 PM
WindKnot
1977 CJ7
I have this console and am very happy with it. I have some pictures that might help answer some questions. The Jeep was ridden hard and put away wet though. It's kind of dirty. But that's a good thing, right?
The console will go anywhere you want it. You will drill three holes. What would've been cool is a template. Make one by tracing the holes at the bottom of the box and life will go much smoother.
In the bottom of the cup holder tray are two phillips head screws. As was posted earlier, if you don't want them, remove them before you install the console. Because if you change your mind later you'll need to remove the console.
Yes you could drill holes for speakers. Of course it's going to intrude on your storage. The metal is at least as thick as on an ammo can, maybe even approaching the thickness of the dash.
The box is definitely splashproof as is. I believe there is enough play in the latch mechanism to add some weatherstripping inside the lid so that it comes down on the edge of the walls and you'll be fine. I am verymuch impressed with the overall quality of the box. The vinyl is certainly tear resistant, the hinge is a piano hinge and the locking latch is good (and replaceable) I would buy it again.
Here's a little better picture of the existing weatherstripping on the lid. I would add some more along the bottom so that it squishes when you close the lid.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #14 of 19 Old 03-21-2012, 06:46 PM
Hurricane4
silentmike - I use a Harbor Freight trailer tongue box behind the rear seat of my CJ7.
I realize you have a 5 but this might be worth a look especially for the price.
http://www.harborfreight.com/35-inch...box-66244.html
http://www.jeepforum.com/forum/f8/re...nting-1253399/
http://www.jeepforum.com/forum/f8/diy-trunk-1129333/
The unbelievable we can do immediately . . . the impossible just takes a little longer.
Hurricane4 is offline
post #15 of 19 Old 03-21-2012, 08:08 PM Thread Starter
tamu83cj
1983 CJ7
Project23, I sent you a PM if you get a chance to look it over. Thanks.
tamu83cj is offline
Center console? Cutlass327 Jeep CJ Forum 2 03-11-2010 07:59 AM
Center Console for 82 CJ5 Beninpcb Jeep CJ Forum 5 06-04-2009 11:14 AM
Smitty Built Center Console mike4089 Jeep CJ Forum 6 01-26-2009 10:29 AM
center console and stereo setup advice? JUNK726 Jeep CJ Forum 8 12-09-2008 04:10 PM
Smittybilt Center Stereo Console Advice TJTony Jeep CJ Forum 7 01-03-2008 10:15 AM
