Small plan to change springs and shackles turned into a major mod! - Page 2 - JeepForum.com
post #16 of 19 Old 09-08-2011, 02:18 AM Thread Starter
LordSul
1975 CJ5
Now that the 1" body lift is on, Im out to try a flex, and see how the shackles do.
For a reason, which I suspect, its the front hangers angle, front axle is not flexing much. Maybe its the front shaft, I couldnt figure it out.
Ill cover MSD setup in a new thread.
Thanks everyone for your help, it has been a painful couple of months.
76' Jeep CJ7, AMC 232, Weber Carb 32/36, TeamRushed, MSD6, 33" Maxxis Mudzilla
"Tear down the walls of Nicosia"
LordSul is offline
post #17 of 19 Old 09-08-2011, 02:45 AM Thread Starter
LordSul
1975 CJ5
This is how my old setup used to look,
Shackles and springs!
After the spring lift, shocks, drop pitman and axle angle adjustments, ride quality has improved 100%. I no longer have roll when turning corners, I have more stable steering, no wandering. I used to have squeaks and crack sounds when I got over bumps, now I can hear the sound of my tires and exhaust only.
Its incredible how a couple of rod angles and geometry alteration, changes your driving quality. It wouldnt be too much if I said, its as if I have a new jeep.
LordSul is offline
post #18 of 19 Old 09-08-2011, 09:51 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Shouldn't there be a little more angle on that u-joint? You usually want a couple degrees on there to have the u-joint still flex a bit to keep the grease moving a little and so that the bearings don't just wear in the same spot the whole time. I could be wrong, since I know CV shaft angles are different from normal shaft angles.
Rick
Cutlass327 is offline
post #19 of 19 Old 09-08-2011, 10:42 PM Thread Starter
LordSul
1975 CJ5
Yes, you are right, it did need a couple of degrees on that joint, but I do have technical difficulties in making mechanics, do the things exactly the way I want.
It is an easy thing, to take out the shims, decrease their angle then put it back on.
thanks
LordSul is offline
What Shackles to get with 4" springs LibertyJeeper Jeep CJ Forum 8 03-05-2011 01:11 PM
Proper way to change out shackles on my cj7. BG33 Jeep CJ Forum 5 12-29-2009 10:59 AM
Shackles, Shocks, and Springs tamu83cj Jeep CJ Forum 1 04-28-2005 10:21 PM
Shackles for Reversal w/ YJ Springs? MudLover Jeep CJ Forum 2 02-16-2005 09:48 AM
Bolting springs to shackles bstruckm Jeep CJ Forum 2 06-18-2003 11:44 AM
