Slave cylinder on 85 CJ7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Slave cylinder on 85 CJ7
Rough Country Lift Kits and Parts!The ULTIMATE "Selectable" Locker System! BroughIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-07-2013, 11:11 PM   #1
graydragon2
I need some advice. I had to bleed my clutch and I am trying to put it back together. When I put the slave cylinder back on the pedal will not press in. I think what is happening is that the pushrod is catching against the lip inside the bell housing and not letting the clutch operate. Any ideas how I can get it back together and make sure the pushrod is going in without having to keep taking it back off. The clutch is working fine when I dont have the slave bolted down.It is an 85 CJ7 2.5L
graydragon2 is offline   Reply With Quote
Unread 09-08-2013, 09:37 AM   #2
graydragon2
Figured it out. The pushrod was sliding off the fork and not engaging. One of those things where I needed three hands.
Unread 09-08-2013, 04:18 PM   #3
LumpyGrits
Hydro clutch linkage is not OEM for that Jeep.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is online now   Reply With Quote
Unread 09-08-2013, 08:48 PM   #4
gosupes
LG
Not for the 258, but the AMC 150 4 banger was hydraulic which is what the OP has.
1986 CJ7, 4.2 w/4.0 head, TFI-HEI hybrid ignition, Clifford manifold w/Holley 390 w/cold air intake, OBA, 4.5" lift, Woody CV shaft and Tattons in front, 4.10 gears - lunchbox in front, Truetrac in the back, twin-sticked, blower upgrade for running topless, trying to keep it simple.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline   Reply With Quote
Unread 09-08-2013, 08:50 PM   #5
Mean Max
Don't poke the bear
Mean Max's Avatar
Sure nuff.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is online now   Reply With Quote
Unread 09-08-2013, 09:14 PM   #6
BagusJeep
BagusJeep's Avatar
1981 CJ7
And on the 258 it was standard for all Right Hand Drive markets, where people drive as God intended, on the right.
I have several and they work just fine.
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote
Unread 09-09-2013, 07:22 AM   #7
graydragon2
Wish I had the 258. When this engine gives out or I have the extra $$$ I'm probably gonna swap for the 258. My dad has the 258 in his 83 CJ7 and has not had any problems with it.
Unread 09-09-2013, 09:18 AM   #8
LumpyGrits
Yup, wasn't think'n 4 popper
THX,
LG
