Skyjacker Nitro or Hydro? - JeepForum.com
post #1 of 11 Old 03-14-2007, 06:59 AM Thread Starter
egabriella
I hope this hasn't been beat to death- I did a search and couldn't find any good answer. Besides the obvious, what is the difference between Skyjacker Nitro or Hydro shocks? I have Rancho 5000's and I'm looking to switch shocks for a softer ride. I know it's a CJ and it's not going to ride like coils, but I would like to go a little softer. I've heard the Hydro's give a great ride, but I haven't been able to find much about the Nitro's.
Sure glad CJ owners still wave..
'82 CJ7 360, T-5, M20 and D30 w/Tru-Trac's, 4.5", 33's
'06 WRX STI
'95 Honda Prelude V-Tec
'97 Mazda Millenia DD
'71 240Z project
egabriella is offline
post #2 of 11 Old 03-14-2007, 09:44 AM
CJ_Mike
This past weekend I actually swapped out my rancho 5000's for some skyjacker 7000 hydros. But my reasoning is that my rancho 5000's werent long enough for the lift that I have. But as I was putting in the new ones, and taking out the ranchos, the hydros seemed a little softer. Also, once i had them in and drove it around, the ride seemed a little softer. It was noticible, but only slightly. No major change in ride
CJ_Mike is offline
post #3 of 11 Old 03-14-2007, 09:53 AM Thread Starter
egabriella
That's exactly the situation I'm in, and about what I expected. Thanks for the info.
'06 WRX STI
'71 240Z project
post #4 of 11 Old 03-15-2007, 12:15 AM
only in a jeep cj
I got a set of hydros and thought there was cement inside them! I will stay with my rancho 9000s on setting 1 ....way softer.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #5 of 11 Old 03-15-2007, 01:34 PM
Mud Machine
Jeep Addict
Mud Machine's Avatar
I'm running Hydro's on mine and they ride great on and off road. I run my Jeep mainly on technical trails and in the mud so these shocks are perfect. If you do any high speed running or like to get some air I would go with Nitro's. Unfortunately these are the only shocks that I have had on my Jeep so I can not make any comparisons for you.
BDS Springs, MetalCloak Arms, Fox Shocks, Warn Winch, Savvy Ft Bumper, Antirock, GenRight Fenders, GR8 Top, 35" Pittbulls, 5.13's, Revolution Axle Shafts, LS-III, 4L80e
'76 CJ-7, 33" Swampers, 6-Point Cage, 4-Speed, Dana 300 Twin Stick
Mud Machine is offline
post #6 of 11 Old 03-15-2007, 01:46 PM
CJ Chet
Quadratec has a nice chart that compares all types of shocks by ride, lift, dimensions, etc. (Shock Advisory). It's very helpful.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #7 of 11 Old 03-15-2007, 02:46 PM
SuB8HaVeN
I run those Skyjacker Hydros on mine and they work great. The ride is great both on and off road.
1986 Jeep CJ7 4.2L I6 T176 (restoration in progress)
1961 Willys 4x4 Wagon L-226 I6 T90 (restoration also in progress)
SuB8HaVeN is offline
post #8 of 11 Old 03-15-2007, 06:32 PM
GPER
1979 CJ7
The Nito's are stiffer than the Hydro's, so I run the Nitro's on my 4500 pound cj.
GPER is offline
post #9 of 11 Old 03-15-2007, 07:50 PM
maddogfx
Chew thru the leash
maddogfx's Avatar
What are the advantages of each? (durability, life expectancy and ride) I'm looking at lifting mine and am new with jeeps, any help would be appreciated.
2005 TJ Rubicon ("Thumper")
maddogfx is offline
post #10 of 11 Old 03-16-2007, 07:13 AM
Mud Machine
Jeep Addict
I would assume that the durability and life expectancy would be the same on both shocks. Which type you choose should really be based on how you intend on using your Jeep.
Hydro's: Excel for slower speeds such as normal trail running, technical trails, mud, and any other terrain that is taken at a normal or slower speed. They would also tend to let you articulate a little better within your suspension travel due to less resistance. These will offer a smoother ride in these conditions as well as on road.
Nitro's: Excel at higher speeds such as blasting dunes, high speed over rough trails or back roads, or if you get air time on a regular basis. These will offer a firmer ride on and off road.
post #11 of 11 Old 03-16-2007, 07:40 AM
maddogfx
Chew thru the leash
maddogfx's Avatar
Thanks for the guidance, that's exactly what I needed to know. I appreciate your help.
maddogfx is offline
hydro clutch conversion fridaniki Jeep CJ Forum 5 03-07-2008 10:26 AM
Hydro Clutch DeltaSigCJ5 Jeep CJ Forum 3 10-22-2007 07:17 PM
hydro boost help!!!! jlynch Jeep CJ Forum 13 03-04-2006 08:02 AM
hydro boost question jlynch Jeep CJ Forum 9 02-12-2006 08:38 AM
nitro vs. hydro certifiablejeep Jeep CJ Forum 3 10-23-2002 05:00 PM
